Scene not responding Or Not Being Run
  • Scene not responding Or Not Being Run
    I wonder if anyone could tell me why Alexa says these scenes will either 'not respond' or Alexa will say 'ok' but nothing happens?
    I think, and someone correct me if I'm wrong, you are using the built-in HomeSeer voice commands instead of Alexa voice commands. The "Phrase" and the "confirm voice command" are used with HomeSeer's voice command process, not Alexa.
    What I would recommend is to use a Virtual Device for your scene and populate the voice command with "arrive home" and see if that turns it on/off. You can then build an event to execute based off that virtual device changing.
    68 Z-Wave Nodes, 174 Events, 326 Devices
      Ahhhh ok. Many thanks for your help.
