OMNI Plugin v3.0.2.8 - duplicate link on startup
    Not sure if this is related to Homeseer 3 V.435.
    I only see this with the Omni Plugin and none of the other PI's.
    See this on start up.
    Apr-28 7:28:07 AM Startup
    Apr-28 7:28:07 AM Startup ************************************************************ ********************
    Apr-28 7:28:07 AM Startup HomeSeer version 3.0.0.435 Edition: HS3 Pro Starting Now
    Apr-28 7:28:07 AM Startup Creating Class Objects...
    Apr-28 7:28:07 AM Startup Checking for available plug-ins
    Apr-28 7:28:07 AM Plug-In Found plug-in: OMNI, version: 3.0.2.8
    Apr-28 7:28:08 AM Startup Initializing Plug-Ins
    Apr-28 7:28:08 AM Plug-In Finished initializing plug-in OMNI
    Apr-28 7:28:08 AM Info Plugin OMNI has connected. IP:127.0.0.1:55918
    Apr-28 7:28:09 AM Starting Plug-In Initializing plugin OMNI ...
    Apr-28 7:28:09 AM Warning Attempt by plugin to register a duplicate link of OMNI. Plugin: OMNI Instance:
    Apr-28 7:28:11 AM Starting Plug-In Plugin OMNI started successfully in 2060 milliseconds
    - Pete
    Auto mator
    HS4 Pro - Ubuntu 22.04 / Lenova Tiny M900 / 32Gb Ram
    Thanks Pete. I sure thought that was fixed in the latest version.
    HS4Pro on a Raspberry Pi4
    54 Z-Wave Nodes / 21 Zigbee Devices / 108 Events / 767 Devices
    Plugins: Z-Wave / Zigbee Plus / EasyTrigger / AK Weather / OMNI
    HSTouch Clients: 1 Android
      Yup... I'm seeing that too with OMNI. Also with MCSSprinklers, but I dropped a note to Michael about that some time ago.
        I have a couple of users running .435 reporting the same with my plugins. I haven't seen it myself.
        Do any developers have a clue on what's going on?
          It's possible that the new method that HS3 uses to start plugins is causing it.
          The issue is that the plugin tries to register a new page and there is already one registered. It shouldnt cause any issues. The fix is to check to see if it is already registered before creating a new link.
            Aha, is there a method to do that already? How are you doing this?
              I am receiving the error "Jul-31 11:37:12 AM Warning Attempt by plugin to register a duplicate link of OMNI. Plugin: OMNI Instance:". I am using HomeSeer version 3.0.0.435 and OMNI plugin, version: 3.0.2.15. My platform is Windows 7 Pro with all updates.
              Please advise if their is a fix or workaround. The system is unworkable at the moment.
                That message is a warning that there is already a web page for OMNI. It doesnt affect the plugin. What are in your logs?
                  The error received is "HSPI_OMNI has stopped working". Below is the full log from startup.
                  Aug-01 10:05:34 AM Info Plugin OMNI with instance: has disconnected
                  Aug-01 10:05:17 AM Warning Plugin OMNI is not responding but it is still running, not restarting yet.
                  Aug-01 10:04:47 AM Warning Plugin OMNI is not responding but it is still running, not restarting yet.
                  Aug-01 10:03:50 AM TTS Speak ():Welcome to Home-Seer
                  Aug-01 10:03:49 AM Speaker Speaker host added, Name: Stone436 Instance: Default IP address: 127.0.0.1
                  Aug-01 10:03:49 AM Starting Plug-In Plugin OMNI started successfully in 2024 milliseconds
                  Aug-01 10:03:48 AM Info System connected to MyHS Service successfully with license ID 117161.
                  Aug-01 10:03:48 AM Info System connected to MyHS Service, waiting for acknowledge...
                  Aug-01 10:03:48 AM Startup Start up complete.
                  Aug-01 10:03:48 AM Startup HSSentry is disabled in Setup, sentry will not be started.
                  Aug-01 10:03:48 AM Startup (Startup.vb script) No speaker clients detected, waiting up to 30 seconds for any to connect...
                  Aug-01 10:03:48 AM Startup (Startup.vb script) Scripting is OK and is now running Startup.vb
                  Aug-01 10:03:48 AM Startup Starting Event Scheduler...
                  Aug-01 10:03:48 AM Startup Running the startup script Startup.vb
                  Aug-01 10:03:48 AM Info Starting speaker client...
                  Aug-01 10:03:48 AM Startup Starting Find service...
                  Aug-01 10:03:48 AM Startup Updater services starting...
                  Aug-01 10:03:48 AM Database Opening (Mode=Read/Write) up HomeSeer Energy database C:\Program Files (x86)\HomeSeer HS3\Data\Energy\Energy.hsd
                  Aug-01 10:03:48 AM Speech Listening for remote speaker connections on port 10401
                  Aug-01 10:03:48 AM Startup Initializing Speaker Client Interface
                  Aug-01 10:03:48 AM Startup Start automation engine...
                  Aug-01 10:03:47 AM Web Server Web Server authorized local login successful from: 192.168.1.198 User: default
                  Aug-01 10:03:47 AM Warning Attempt by plugin to register a duplicate link of OMNI. Plugin: OMNI Instance:
                  Aug-01 10:03:47 AM Starting Plug-In Initializing plugin OMNI ...
                  Aug-01 10:03:47 AM Startup Creating ASP.NET application host...
                  Aug-01 10:03:47 AM Web Server Web Server started on port 80
                  Aug-01 10:03:47 AM Web Server Local IP address (subnet) is: 192.168.1.131 (255.255.255.0)
                  Aug-01 10:03:47 AM Info Plugin OMNI has connected. IP:127.0.0.1:52219
                  Aug-01 10:03:47 AM Startup HStouch server started, waiting for clients to connect.
                  Aug-01 10:03:47 AM HSTouch Server Server started on port 10200
                  Aug-01 10:03:47 AM Plug-In Finished initializing plug-in OMNI
                  Aug-01 10:03:47 AM Plug-In Interface OMNI is running as a trial, 29 days remaining.
                  Aug-01 10:03:47 AM Startup Initializing Plug-Ins
                  Aug-01 10:03:47 AM Plug-In Found plug-in: Z-Wave, version: 3.0.1.190
                  Aug-01 10:03:47 AM Plug-In Found plug-in: OMNI, version: 3.0.2.15
                  Aug-01 10:03:47 AM Startup Checking for available plug-ins
                  Aug-01 10:03:47 AM Info Remote plug-in API interface started on port 10400
                  Aug-01 10:03:47 AM Startup This version of HomeSeer is not registered and is running as a trial, 29 days remaining.
                  Aug-01 10:03:47 AM Startup Creating Speaker Client Interface Object...
                  Aug-01 10:03:47 AM Startup HomeSeer version is: 3.0.0.435
                  Aug-01 10:03:47 AM Load Config Loading TIMERS...
                  Aug-01 10:03:47 AM Load Config Loading COUNTERS...
                  Aug-01 10:03:47 AM Load Config 1 total events loaded.
                  Aug-01 10:03:47 AM Load Config Loading Events...
                  Aug-01 10:03:47 AM Load Config Loading Event Groups...
                  Aug-01 10:03:47 AM Load Config 11 total devices loaded.
                  Aug-01 10:03:47 AM Database Loading Devices...
                  Aug-01 10:03:47 AM Database Opening (Mode=Read Only) up HomeSeer database C:\Program Files (x86)\HomeSeer HS3\Data\HomeSeerData.hsd
                  Aug-01 10:03:47 AM Startup Loading configuration file ...
                  Aug-01 10:03:47 AM Startup Database SAVE process started.
                  Aug-01 10:03:47 AM Startup Local voice recognition class started.
                  Aug-01 10:03:47 AM Startup HSPhone external interface class started.
                  Aug-01 10:03:47 AM Startup Plug-In Interface class started.
                  Aug-01 10:03:47 AM Startup E-Mail RECEIVE class started.
                  Aug-01 10:03:47 AM Startup E-Mail SEND class started.
                  Aug-01 10:03:46 AM Startup Web server class started.
                  Aug-01 10:03:46 AM Startup Application interface class started.
                  Aug-01 10:03:46 AM Startup COM port classes started.
                  Aug-01 10:03:46 AM Startup Creating Class Objects...
                  Aug-01 10:03:46 AM Startup ************************************************************ ********************
                  Aug-01 10:03:46 AM Startup HomeSeer version 3.0.0.435 Edition: HS3 Pro Starting Now
                  Aug-01 10:03:46 AM Startup Settings Loaded.
                  65 log entries, displaying entries from 0
                  lastlogid=0&action=update_log
                    In the Logs/ folder, there should be a log file for the OMNI startup.
                    Also, can you post the details of the Windows "stopped responding" message?
                      Here is the content of that log file. I also included as an attachment.
                      8/2/2018 4:32:08 PM ~!~Startup~!~Settings Loaded.
                      8/2/2018 4:32:08 PM ~!~Startup~!~*********************************************** *********************************
                      8/2/2018 4:32:08 PM ~!~Startup~!~ HomeSeer version 3.0.0.435 Edition: HS3 Pro Starting Now
                      8/2/2018 4:32:08 PM ~!~Startup~!~Creating Class Objects...
                      8/2/2018 4:32:08 PM ~!~Startup~!~COM port classes started.
                      8/2/2018 4:32:08 PM ~!~Startup~!~Application interface class started.
                      8/2/2018 4:32:08 PM ~!~Startup~!~Web server class started.
                      8/2/2018 4:32:08 PM ~!~Startup~!~E-Mail SEND class started.
                      8/2/2018 4:32:08 PM ~!~Startup~!~E-Mail RECEIVE class started.
                      8/2/2018 4:32:08 PM ~!~Startup~!~Plug-In Interface class started.
                      8/2/2018 4:32:08 PM ~!~Startup~!~HSPhone external interface class started.
                      8/2/2018 4:32:08 PM ~!~Startup~!~Local voice recognition class started.
                      8/2/2018 4:32:08 PM ~!~Startup~!~Database SAVE process started.
                      8/2/2018 4:32:08 PM ~!~Startup~!~Loading configuration file ...
                      8/2/2018 4:32:08 PM ~!~Database~!~Opening (Mode=Read Only) up HomeSeer database C:\Program Files (x86)\HomeSeer HS3\Data\HomeSeerData.hsd
                      8/2/2018 4:32:08 PM ~!~Database~!~Loading Devices...
                      8/2/2018 4:32:08 PM ~!~Load Config~!~11 total devices loaded.
                      8/2/2018 4:32:08 PM ~!~Load Config~!~Loading Event Groups...
                      8/2/2018 4:32:08 PM ~!~Load Config~!~Loading Events...
                      8/2/2018 4:32:08 PM ~!~Load Config~!~1 total events loaded.
                      8/2/2018 4:32:08 PM ~!~Load Config~!~Loading COUNTERS...
                      8/2/2018 4:32:08 PM ~!~Load Config~!~Loading TIMERS...
                      8/2/2018 4:32:08 PM ~!~Startup~!~HomeSeer version is: 3.0.0.435
                      8/2/2018 4:32:08 PM ~!~Startup~!~Creating Speaker Client Interface Object...
                      8/2/2018 4:32:08 PM ~!~Startup~!~This version of HomeSeer is not registered and is running as a trial, 27 days remaining.
                      8/2/2018 4:32:08 PM ~!~Info~!~Remote plug-in API interface started on port 10400
                      8/2/2018 4:32:08 PM ~!~Startup~!~Checking for available plug-ins
                      8/2/2018 4:32:08 PM ~!~Plug-In~!~Found plug-in: OMNI, version: 3.0.2.15
                      8/2/2018 4:32:08 PM ~!~Plug-In~!~Found plug-in: Z-Wave, version: 3.0.1.190
                      8/2/2018 4:32:08 PM ~!~Startup~!~Initializing Plug-Ins
                      8/2/2018 4:32:08 PM ~!~Plug-In~!~Interface OMNI is running as a trial, 27 days remaining.
                      8/2/2018 4:32:08 PM ~!~Plug-In~!~Finished initializing plug-in OMNI
                      8/2/2018 4:32:08 PM ~!~HSTouch Server~!~Server started on port 10200
                      8/2/2018 4:32:08 PM ~!~Startup~!~HStouch server started, waiting for clients to connect.
                      8/2/2018 4:32:08 PM ~!~Info~!~Plugin OMNI has connected. IP:127.0.0.1:59199
                      8/2/2018 4:32:08 PM ~!~Web Server~!~Local IP address (subnet) is: 192.168.1.131 (255.255.255.0)
                      8/2/2018 4:32:08 PM ~!~Web Server~!~Web Server started on port 80
                      8/2/2018 4:32:08 PM ~!~Startup~!~Creating ASP.NET application host...
                      8/2/2018 4:32:08 PM ~!~Starting Plug-In~!~Initializing plugin OMNI ...
                      8/2/2018 4:32:08 PM ~!~Warning~!~Attempt by plugin to register a duplicate link of OMNI. Plugin: OMNI Instance:
                      8/2/2018 4:32:09 PM ~!~Startup~!~Start automation engine...
                      8/2/2018 4:32:09 PM ~!~Startup~!~Initializing Speaker Client Interface
                      8/2/2018 4:32:09 PM ~!~Speech~!~Listening for remote speaker connections on port 10401
                      8/2/2018 4:32:09 PM ~!~Database~!~Opening (Mode=Read/Write) up HomeSeer Energy database C:\Program Files (x86)\HomeSeer HS3\Data\Energy\Energy.hsd
                      8/2/2018 4:32:09 PM ~!~Startup~!~Updater services starting...
                      8/2/2018 4:32:09 PM ~!~Startup~!~Starting Find service...
                      8/2/2018 4:32:09 PM ~!~Info~!~Starting speaker client...
                        That startup looks fine to me. There are no errors found.
                        Are you able to go into the OMNI config to enter your IP and keys?
                          Yes. Able to configure and starts up. Immediately then fails with error above. PS. Apologies as I am traveling next 8 days with no communication. I do appreciate your help on this.
                            Hi, Is there any update on this?
                              Load up the latest version and try it out. Capture and send the looks if it happens again.
                              Sent from my Galaxy S7 Edge using Tapatalk
