OMNI Plugin v3.0.2.18
This topic is closed.
  • #16
    Originally posted by getmp3s View Post
    Did you resolve this issue i n.18? i've been holding off on upgrading from .17 to .18 based on your comment that all dimming will fail. Let me know how you made out. Thanks.
    Ditto. 😁
    Sent from my SM-G965U1 using Tapatalk
    • #17
      Originally posted by avpman View Post
      Ditto. 😁
      I took the plunge regardless and upgradeded. Dimming still works .
      • #18
        Dimming still doesn’t work for me, and for once didn’t back up. Urg. Absent of any suggestions, waiting patiently for next upgrade. Happy New Year.
        • #19
          What kind of devices/units do you have?
          Sent from my Galaxy S7 Edge using Tapatalk
          68 Z-Wave Nodes, 174 Events, 326 Devices
          • #20
            I have an Omni II and 50 or so ALC switches. No other device types. Dimming has always worked perfectly until now. 🤔
            • #21
              Did this dimming issue ever get fully resolved. I am afraid to update. Probably wouldn't be so afraid if I knew how to do a backup first so I was confident I could restore to the status quo.
              • #22
                Here just tested V3.0.2.18 with UPB and one unit. Working fine.
                Here are the log entries while I watched the lamp dim.
                1/20/2019 6:23:21 PM [2] [--> Unit 51 changed status. Updating Homeseer...]
                1/20/2019 6:23:21 PM [2] [-->Unsolicited: Unit=[51] status=[0]/[OFF] type=[4] / []]
                1/20/2019 6:23:21 PM [2] [-->UNIT: desc=[] number=[51] name=[Hallway Back]]
                1/20/2019 6:23:21 PM [2] [---->Unit]
                1/20/2019 6:23:21 PM [2] [UNSOLICITED: ExtendedStatus]
                1/20/2019 6:23:21 PM [2] [Unit_Off: unitId=51 ]
                1/20/2019 6:23:21 PM [2] [SetIOMulti: CC.Ref=[1113] CC.ControlValue=[0]]
                1/20/2019 6:23:16 PM [2] [--> Unit 51 changed status. Updating Homeseer...]
                1/20/2019 6:23:16 PM [2] [-->Unsolicited: Unit=[51] status=[149]/[LEVEL 49%] type=[4] / []]
                1/20/2019 6:23:16 PM [2] [-->UNIT: desc=[] number=[51] name=[Hallway Back]]
                1/20/2019 6:23:16 PM [2] [---->Unit]
                1 - shut down Homeseer
                2 - back up the Homeseer directory
                3 - start up Homeseer
                4 - update the Omni Plugin to V.18
                5 - test the plugin with one device
                6 - if it does not work then delete the unit variable that it creates and let the plugin recreate the same variable
                7 - test it again.
                8 - if it works then you are OK.
                9 - if it doesn't work then
                10 - shut down Homeseer
                11 - copy backed up Homeseer directory back to Homeseer
                12 - start up Homeseer and you will be back to previous Omni version.
                - Pete
                Auto mator
                HS4 Pro - V4.0.9.0 - Ubuntu 18.04/W7e 64 bit Intel Kaby Lake CPU - 32Gb - Mono 6.8X
                HS4 Lite -
                • #23
                  v3.0.2.20 was released to the updater today...
