I'm new to the automation with homeseer. Homeseer discovers my OMNI IIE and my OMNISTAT hardware, When I enable the Thermostats. It goes green but when I look at the Device List it says not set and when I look at my homeseer app it list the temp but will not adjust. I have removed it and reloaded but still get the same outcome.
Rc-2000 Omnistat and homeSeer
Make sure logging is set to debug in the Omni plug-in config, then try to control the thermostat. Post the Omni logs and let me see if I can spot anything.
Sent from my Galaxy S7 Edge using Tapatalk
HS4Pro on a Raspberry Pi4
54 Z-Wave Nodes / 21 Zigbee Devices / 108 Events / 767 Devices
Plugins: Z-Wave / Zigbee Plus / EasyTrigger / AK Weather / OMNI
HSTouch Clients: 1 Android
Originally posted by jjarvis728 View PostAny update on my issue
That log file didnt contain any thermostat messages, so I would turn off the MySQL option, restart the plugin, then control the thermostat and let's see if anything gets logged.HS4Pro on a Raspberry Pi4
Originally posted by jjarvis728 View PostOnce I remove the SQL it work like a charm. Thank you. The only error I'm getting that Temp/humidity receive for zone 16 but zone is not setup in homeseer. Can you tell me the correct way to set that up.HS4Pro on a Raspberry Pi4
Originally posted by jjarvis728 View PostThat what I'm missing. When I go to temp/Humidity there is no check boxes. it tell me you must tell the plugin which zone you want to track in HSHS4Pro on a Raspberry Pi4
