HS Database Unit Disassociation with Plugin DB
  • #16
    rmasonjr Very odd... I looked at devices that had 1 named entry and now they are showing 2 named entries!
    I did manage to find one that still showed 1 named entry. I removed it via the Plugin which also removed the HS device.
    1- device removed
    2- Event and script, done
    3- device recreated via plugin
    Device as created:
    Extra Data Store 2 Named entries, 0 UnNamed entries.
    Let's see...
    • #17
      Just tried to set a light with HSTouch and nothing.
      Checked the plugin units page and the "enable" switch has turned red, it has disassociated. This is not the device I previously reported and created. The log entries only show:
      Jan-04 7:00:00 PM Event Running script statement immediately: &hs.SaveEventsDevices()
      No other related entries that I can see related.
      This device routinely disconnects:
      Reference ID 205
      Technology Address OMNI-Q56
      Status 0 = OFF
      Value 0 = "OFF"
      String
      Supports Status True
      Dimmable True
      Interface OMNI
      Extra Data Store 1 Named entries, 0 UnNamed entries.
      Device Type Internal Plug-In API, Type: Plug-In Type 4, SubType: DiningRmLite
      Device Type (String)
      Misc Settings Do Not Log, Show Values, Generate Voice Command, SET_DOES_NOT_CHANGE_LAST_CHANGE
      Device Image File images/HAI/hai.jpg
      Thumbnail Image File images/HAI/hai.jpg
      Relationship Status Child
      Associated Devices .Hidden OMNI Root Device
      Additional Display Data OMNI
      3.0.2.18
      A couple of days ago it showed 2 Named Entries. Odd.
      Otherwise, the system is ticking along fine.
      • #18
        The script event has been running since 2-January. Nothing remarkable in the log file.
        Jan-09 3:00:00 PM Event Running script statement immediately: &hs.SaveEventsDevices()
        Jan-09 2:00:00 PM Event Running script statement immediately: &hs.SaveEventsDevices()
        Entries just like these every hour since 2-JAN.
        This device did become orphaned since setting everything back. I have not deleted it and reenabled it. Just letting it sit.
        Reference ID 205
        Status 0 = OFF
        Value 0 = "OFF"
        String
        Dimmable True
        Interface OMNI
        3.0.2.18
        I checked 60 other units and they all have 2 Named entries and working fine. It's almost always this, DiningRmLite, device that dissociates but I have had others go away too and it will include this one.
        • #19
          raprap
          v3.0.2.20 was released to the updater today. Give it a try when you see it...
          • #20
            rmasonjr Thanks, much. I will look out for it.
            Does this update also address the dimming (or lack of) with ON/OFF or 0%/100% commands?
            i.e. Use slider or voice to set 50% (or any number other than 0% or 100%), UPB lights use the default rate but, if you turn the light ON or OFF or "dim/set" to 0% or 100% the light slams ON/OFF and disregards the default rate. Seems to be no difference with the Ramp? checkbox checked/unchecked.
            • #21
              No dimming changes were made in this version.
