OMNI Monitoring of Panel Battery Status
  • OMNI Monitoring of Panel Battery Status
    I would like to be able to monitor via the OMNI plugin the battery status (scaled voltage under test) in each of my OmniPro II main panel and two expansion panels. I have not been able to figure out how to do this.
    Am I missing something? If not, would you take this as a request for a future enhancement?
    Thanks.
    You can see battery voltage under system variables in the Omni plugin.
    For secondary panel here only have a zone trouble connection for the battery. No voltage.
    Note that the battery voltage rarely changes and here by default just change the batteries every 3 years or so.
    - Pete
    Auto mator
    HS4 Pro - V4.0.5.0 - Ubuntu 18.04/W7e 64 bit Intel Kaby Lake CPU - 32Gb - Mono 6.8X
    HS4 Lite -
