I've been using the plugin for many years but I've never had to do this particular action.
I'm trying to set a flag on the OMNI using a vb script from HS. I tried hs.SetDeviceValue but realized that all that does is change the value in the object on the HS side but does not communicate this to the OMNI. Has someone already solved this problem?
I know i can set a flag using any HS action to a pre-defined value (using the dropdown) but how else would I set the value through an action when I need to read the value in as a parameter?
Appreciate your thoughts!
