Start from scratch
  • #16
    Zee
    • #17
      In that case, there should be a :911 port on the Zee that will allow a factory reset. In a browser, enter the IP address of your Zee with the port :911 at the end.
      68 Z-Wave Nodes, 174 Events, 326 Devices
      • #18
        The odd thing is I turned off the TSTATS and Units and restarted Homeseer. I disabled the 2 Homeseer skills. Discovered devices and the units appear. I then enabled both skills and get duplicates of the units in Alexa only iPhone Alexa app but only one on the Alexa web interface. All very odd.
        When I try to control unit with the Alexa app manually it gets stuck on Waiting for Homeseer. If I talk to Alexa the unit works.
        Should I enable the Homeseer Smarthome Skill or the Homeseer Home Automation Skill or both?
        • #19
          You can use either skill. One requires you to use "Alexa, tell HomeSeer to..." and the other just uses "Alexa, turn on the..."
          • #20
            I noticed that even though all the units where off one of the locks would not go away in Alexa. I turned off all locks and the units appeared again. Think I might be good now.
