Hello everyone, first post here! (collective sigh)
I'm in the middle of a move to a new home, leaving a home I built back in 2006 which I automated with an HAI Omni II (later upgraded to a IIE) and HAI UPB switches. Overall I was very pleased with the way things worked, it proved to be very reliable and responsive.
Now I find myself moving to a new house and looking to add in new things that have become available since 2006 so I'll be adding HomeSeer to the mix as well as some Alexa.
I still plan on using an Omni for the security end, all the wired door/window/pir etc will go to that unit. After that I'm not sure if I should stay with UPB or move to Insteon which "sounds" like it has all the goodness of powerline communication with RF mesh. So here come the questions that I hope I can get some input on.
- Does anyone have experience with using Omni zone status to trigger Insteon lights, and if so is it as responsive as "standalone" Omni UPB solution? I was planning on using the Hub2 for the Insteon interface if that makes a difference.
- If I stay with UPB is it better to let the Omni issue the commands with the PIM hooked to the Omni or should I use a PCS PIM-U on the HomeSeer box and send UPB commands from Homeseer based on Omni zone status? Is there any difference in responsiveness here
- Related to the above, is it possible to use the PCS PIM-S directly on the Omni? I see that PCS has a PCS OPA adapter for this purpose but I've not found hide nor hair of that item. Is that simply the Leveton 36A05-2 HAU PIM to Serial adapter?
I'm sure I'll have more questions as I begin to set things up since I've not used HomeSeer before, so far I have the HomeSeer software and the Omni plugin. But for now I'm just wanting to settle on the switch technology and PIM locatoin (Omni or HomeSeer box).
