Omni IIe Units and Outputs
  • Omni IIe Units and Outputs
    The five defaut outputs on the panel show up as "units" that are dimmable in HomeSeer.
    Shouldn't these be on the "Output" tab?
    65 (OUT1) OPN H2O Main Output 0 / OFF
    66 (OUT2) CLS H2O Main Output 0 / OFF
    67 (OUT3) Relay#3 Output 0 / OFF
    68 (OUT4) Relay #4 Output 0 / OFF
    69 (OUT5) WatV CLSDLED Output 0 / OFF
    The Output tab shows:
    Basic Panel Outputs
    # Annotation Name Type Status HS Device
    385 (EX1) Output OFF
    386 (EX1) Output OFF
    387 (EX1) Output OFF
    388 (EX1) Output OFF
    389 (EX1) Output OFF
    390 (EX1) Output OFF
    391 (EX1) Output OFF
    392 (EX1) Output OFF
    By default, the panel supports outputs as unit numbers 385 to 392. You must tell the plugin which outputs you want to track in HS.
    Not sure what these refer to. Are these for a different panel?
    Don't know why there is a reference to units in the outputs. It is just outputs and they are defined starting at #385 and are not controllable like like light units.
    When I create a Homeseer device from an output still see the #385 unless I rename it.
    In PCA they are also referred to as #385 and OUT1 and Unit 385. That said you cannot control unit 385 as a lamp or appliance device.
    Delete HS3 created devices 65 to 69. This looks like the HS3 DB got scrambled a bit. Somewhere there HS3 wrote over light units 65 to 69 with outputs.
    1 - disable outputs on the tab
    2 - delete the created outputs (including number 65 to 69)
    3 - enable define outputs on the tabbed configuration stuff.
    4 - the HAI omni Plugin will create new HS devices defined as outputs with number references 385 up.
    - Pete
    Auto mator
    HS4 Pro - V4.0.5.0 - Ubuntu 18.04/W7e 64 bit Intel Kaby Lake CPU - 32Gb - Mono 6.8X
    HS4 Lite -
      Thanks Pete I never looked at the outputs until yesterday and only created one HS device today to monitor the status. That's when I saw the dimmable switch be created in HS.
      But, but... the OPIIe shows:
      The outputs on the panel are 065 - 074. User definable through 072. I have never seen any reference to 385...etc
      I would presume the plugin to replicate what the panel has unless 065 - 072 are mapped to 385 - 392 for some reason?
        Ahh...it must be different on the Omni IIe than the Omni Pro 2.
        So really the firmware on the Omni IIe is different than the firmware on the Omni Pro.
        I've attached the installation manual for the OPIIe which you probably already have.
        CONTROLLER OUTPUTS
        The Omni IIe provides 8 programmable hardwired voltage outputs and two horn voltage outputs. These outputs are
        programmable for the following output types:
        General Purpose low voltage switching applications (12 VDC) - Units 65 - 72
        • Sounder triggering (a trigger for siren and voice drivers for BURG and FIRE)
        • Communicator outputs (radio, cellular, or any other type of auxiliary communicator)
        • 'ARMED' and 'OK TO ARM' outputs
        • Switched Output (to power smoke detectors and cycle power to latching devices)
        Outputs 1 - 8 can supply a maximum of 100 mA each. These outputs are included in the total DEVICES load, which cannot
        exceed 1A. If the Interior or Exterior Sounder is configured to an Output Type, the HORN outputs can supply a maximum of
        1A. HORN outputs are included in the total HORNS load, which can not exceed 1A.
        Rob also has an Omni Pro 2. The plugin see's the different panel types but looks to be assuming that units 65-72 are light units rather than outputs.
        Here too I assumed that the OPIIe firmware was the same as the Omni Pro II and just disabled some features available on the OmniPro 2.
        yes
        Apologies I am only familiar with my two Omni Pro 2 boards and only have installed and programmed these for friends and relatives.
        Please let Rob know about this. This will be a minor correction to current version of the Omni Plugin relating to your OPIIe panel.
        PK-93404-10-B0-0A-W.pdf
        - Pete
        Auto mator
        HS4 Lite -
          Exactly what you said. The plugin detects the panel type (IIe) but is not managing some of the differences. I presume Rob monitors these threads but just in case rmasonjr
          And using the following output types (with nothing wired)
          Is a great quick and dirty way to determine in HS when the panel is armed or not (without knowing the mode it's armed in). Something that I want to do but cannot figure out in the plugin anything that represent the panel's armed state. I've tried events on one of the zone values but no luck and no time to play with it.
          HAPPY NEW YEAR everyone!
          CONTROLLER OUTPUTS
          yes
            Here for the old HAI Homeseer 2 plugin used the following status:
            HAI_system - security status - Armed Night Delayed
            Panel Status: Armed Night Delayed
            For the Omni Plugin use:
            Omni Area Mode - In House - Arm Night Delayed
            Front Door - Armed - Secure
            You can also configure an automation line to trigger a flag when alarm is enabled.
            Happy New Year!!
            - Pete
            Auto mator
            HS4 Lite -
              Interesting. No such equivalent that I can see in Omni System HS devices created by the plugin. Maybe another OPIIpro v OPIIe panels?
              Happy New Year!!
                I would then maybe just create a flag in the OPIIe automation lines section relating to alarm status maybe?
                Read here for some examples you can try:
                HAI Programming
                - Pete
                Auto mator
                HS4 Lite -
                  I've never seen this before. I checked the code and it literally requests HAC.Units from the panel and that is what is returned.
                  Do you have any expansion panels?
                    Greetings and Happy New Year!
                    No expansion panels only Notifier Board. The digital outputs (some) are wired to an HAI relay board that drives a water valve and an indicator light. That's it. The screen shot is from PCA output configuration section.
                    I fear that there are more differences between the OPIIpro and OPIIe than presumed. My panel firmware is 4.0B.
                      On the main plugin config page, do you have any of the expansion boards selected? The reason I ask is that those annotations in the screenshot are showing EX1, etc
                        No EX selected. To be sure, I checked and restarted the plug-in. Still shows same as screen shot.
                          Does plugin 3.0.0.20 resolve the OPIIe panel output issue in this thread? rmasonjr
                            No - there were no changes related to outputs in this version.
                            Did you try ticking the Expansion #1 checkbox? Those EX1 indicate an expansion panel with outputs.
                              Rob, check back to 3-Jan posts this thread. No expansion panels selected, then I tried to select and restart the plug-in with no change.
                              Maybe by design, Outputs with the OPIIe panel are just units?
                              Don't understand what the Outputs are (385+) though.
