OMNI Plugin v3.0.2.20
  • OMNI Plugin v3.0.2.20
    v3.0.2.20 was released to the updater today.
    Changes in this version:
    • Added - on a panel disconnect, the plugin will attempt a reconnect.
    • Fixed - when selecting 'ramp' option on units, PED was not being updated correctly.
    Always make a backup of your system before loading a new version.
    Post any issues you have with this version in this thread.
    The plugin is now available in the updater.
      Reserved 2
        I can't be 100% sure but it looks like the panel disconnects are better. Disconnecting the switch and reconnecting it a couple of times had no adverse effect. I'm going to try leaving it disconnected for a longer period of time to be sure.
        The lights ramping up or ramp down still don't work.
          yep - working on lighting now...
            I have an Omni 2e and with this new update I am seeing zones 49-64 as being present, however the Omni IIe does not support those. How can I tell the plugin not to look above 48 zones?
              On the main config screen, do you have an OMNI_IIe selected?
              Can you post or email your startup logs?
                Thanks!
                Sent from my SM-G965U1 using Tapatalk
                  Disconnects are almost a thing of the past for me now may be a redo of my Internet system had something to do with it but I’ll give the app the credit.
                  ramping up my lights works great all I have to say is what percent I want and the lights go there immediately up or down.
                  Based on the minimum number of complaints Rob I think you have reached the highest level of performance of the app yet. Thank you very much
                    Thanks Chaser !
