3.0.2.20 Extra Zones on OPIIe
  • 3.0.2.20 Extra Zones on OPIIe
    I have updated to the latest 3.0.2.20 and I found that HS thinks that the OPIIe is capable of 64 zones, where in fact only 48 are supported.
    I end up with about 16 "bad zones" in HS due to this.
    Is there any way in the plugin config to limit the number of zones that are "discovered"?
    Curious if PCA shows the correct number of zones in the status?
    There have been gotcha's in the firmware updating by Leviton fat finger the old stuff writing over it to put in more new features stuff.
    Here removed one area and status shows correct number of areas but everything that accesses the OmniPro 2 panel (Omnitouch stuff, Snaplink, et al) still shows extra area no matter what I do.
    - Pete
    Auto mator
    HS4 Pro - V4.0.5.0 - Ubuntu 18.04/W7e 64 bit Intel Kaby Lake CPU - 32Gb - Mono 6.8X
    HS4 Lite -
      In PCA I see the proper zone info, with a limit of 48 zones.
      The OMNI plug in is looking for the extra zones and I get a.. <BAD ZONE #> (049) and it iterates up through <BAD ZONE #> (064). I did see an entra in the logs that it can;t find the extra zones/
      Is there an entry I can put in the ini file to stop it at 48?
        2/2/2019 12:26:54 AM [2] [CONNECTION STATUS: Connecting]
        2/2/2019 12:26:54 AM [2] [Panel Connected.]
        2/2/2019 12:26:54 AM [2] [Identifying Controller...]
        2/2/2019 12:26:54 AM [2] [HAC.Model=[30] MSG.ModelNumber=[30]]
        2/2/2019 12:26:54 AM [2] [CONTROLLER IS: Omni IIe (4.0B)]
        2/2/2019 12:26:55 AM [1] [Reading panel configuration...]
        2/2/2019 12:26:55 AM [2] [-->SetupData]
        2/2/2019 12:26:59 AM [2] [-->Names_Zone]
        2/2/2019 12:27:00 AM [2] [-->Names_Unit]
        2/2/2019 12:27:01 AM [2] [-->Names_Button]
        2/2/2019 12:27:02 AM [2] [-->Names_Code]
        2/2/2019 12:27:02 AM [2] [-->Names_Area]
        2/2/2019 12:27:02 AM [2] [-->Names_Tstat]
        2/2/2019 12:27:02 AM [2] [-->Names_Message]
        2/2/2019 12:27:03 AM [2] [-->Names_UserSetting]
        2/2/2019 12:27:03 AM [2] [-->Names_AccessControlReader]
        2/2/2019 12:27:03 AM [2] [-->Events]
        2/2/2019 12:27:12 AM [2] [-->Done]
        2/2/2019 12:27:12 AM [2] [Checking 128 Units.]
        2/2/2019 12:27:12 AM [2] [-->Thermostat 1 added to collection.]
        2/2/2019 12:27:14 AM [2] [Checking 48 zones...]
        2/2/2019 12:27:14 AM [1] [All configuration and properties retrieved.]
        2/2/2019 12:27:14 AM [1] [Requesting Area status...]
        Then it moves on to enumerate all my zones such as:
        2/2/2019 12:27:14 AM [2] [MapZoneStatus_V2: zoneId=[1] status=[0] zoneChanged=[False] annotation=[Z1] statusText=[SECURE] zoneType=[0] zoneTypeText=[EntryExit] name=[Entry Doors] area=[1] analogLoop=[148] isNamed=[True] lastStatus=[0] lastStatusText=[] statusLastChangeDate=[2/2/2019 12:27:14 AM] isSecurityZone=[True] isArmingZone=[True] hsDeviceRef=[0] hsParentRef=[0] temperature=[0] humidity=[0] currentCondition=[0] currentStatusText=[SECURE] hsZoneStatus=[0] lowSetpoint=[0] highsetpoint=[0]]
        Then I see about 15 of these after zone 48:
        2/2/2019 12:27:15 AM [2] [Zone status found for a zone that is not present.]
        2/2/2019 12:27:16 AM [2] [Zone status found for a zone that is not present.]
        Thoughts?
          How many zones do you have.?
          Not sure how the Omni plugin and Omni panel interact for the number of zones.
          You could try maybe to shut down the OmniPlugin, delete all of the variables created and delete the Omni DB created and start again to see if it creates the correct number of Zones you are using.
          Thinking too in PCA the zones showing in status are related to the number of hardware expansion boards you have configured.
          I can only do two here on the OP2 panel and have them in place and configured and not all used at this time. (zone only 2 16 port expanders).
          - Pete
          Auto mator
          HS4 Lite -
            I have about 40 Actual zones defined in my Omni. I have 2 expansion boards + the main board for a total of 48 Zones, which is all the Omni IIe supports
            I converted from my Pi Zee to a Intel Nuc running Ubuntu and the linux install. On the PI I am a version behind and did not have these extra zones. These are new to .20. The Nuc is a fresh install + restore
              I also see this in the Omni Plugin
                Make a back up and try to delete all of the extra stuff including the Omni DB and see if it returns to normal IE: 48 zones versus 64 zones.
                Here originally in PCA had an extra area defined which I deleted but somehow it has stuck to my OmniTouch screens and I never have been able to get rid of it. I also see it with the OmniPlugin even though it does not exist. This is a different issue.
                I do not have any external expansion zones or defined:
                Select Expansion Enclosures: Model 17A00
                - Pete
                Auto mator
                HS4 Lite -
                  Thoughts?
                  This means the panel sent an update on a Zone and you dont have it checkmarked in the Zones tab. Clicking the checkbox will create a HS device which will then be updated.
                  I think I answered another post about the zones?
                    Here is the Zones Tab in the OMNI config. It doesn't look like I have any options here
                      Here I am lost. IE: if you do not see these zones in PCA configured for your panel then it may be an issue.
                      Personally I would shut down the plugin, delete all varables created and delete all configuration files and DB files then enable the plugin and see if these zones are there again.
                      They may be there maybe cuz the plugin was initially configured for an OP2 panel, then changed afterwards to your IIe panel.
                      I have not had any experience though with an OPIIe panel. (only Omni Pro 2 first gen and two second generation OP2 panels).
                      - Pete
                      Auto mator
                      HS4 Lite -
                        On the main config screen - do you have your expansion boards checkmarked?
                        Click image for larger version  Name:	image_76606.png Views:	1 Size:	38.6 KB ID:	1284016
                          Nope, not selected
                            Nope, not selected
                            ok - select the expansion boards you have installed, then stop the plugin.
                            Before you start the plugin back up, remove all HAI zone devices in HS.
                            Startup the plugin and you should be set.
                              I performed the above steps and everything seem to be good. Thanks everyone for your help
                              Unconfigured PHP Module
