New Homeseer Box - Omni Plugin - in OP2 can server Part III
  • New Homeseer Box - Omni Plugin - in OP2 can server Part III
    Starting new build here on new box for micro / mini server ....5 watt usage....
    Bought this box this morning on Ebay for $60. They were around same price on Amazon and now have gone up to closer to $80-90.
    Running this one headless inside of the OmnPro 2 media can. It is tiny.
    Click image for larger version  Name:	TX9.jpg Views:	1 Size:	95.3 KB ID:	1299287
    Specs are:
    - Amlogic S912 Octa core SoC (AMLogic S912 Cortex-A53 Octa Core)
    - GPU Mali-T820MP3
    - 3 Gb of DDR3 RAM
    - 32 Gb eMMC
    - Wifi (AC)
    - Gb NIC
    - bluetooth
    OS and stuff
    - Ubuntu 18.04 64 bit (running on 32Gb eMMC) - removing Android (worthless to me).
    - Mono
    - Homeseer 3 mini (Omni Pro plugin)
    - Docker Home Assistant, Node Red
    - webmin
    Easy install
    1 - write OS to booting SD card
    2 - writing image of OS to eMMC
    This mini box runs circles around the RPi, AMD dual core cube and Pine64 and much smaller footprint.
    - Pete
    Auto mator
    HS4 Pro - V4.0.5.0 - Ubuntu 18.04/W7e 64 bit Intel Kaby Lake CPU - 32Gb - Mono 6.8X
    HS4 Lite -
    I'm wondering why this is needed or desired? Is there a significant performance increase with this over the Zee? Or are you using it for things other than Homeseer & Omni plugin?
      Wow - thats an impressive little box. Do you know the power consumption?
        5 watts with Wifi / bluetooth off.
        To install a server inside either the OmniPro 2 media can or the Leviton media panel next to it. I have today migrated much in to the Leviton can...IE: patch panel, 24 port switch, 8 port POE switch, modem (2), W2C boxes, VOIP modem...totally self contained network today. This is separate than the "server" rack in a different location.
        Yes.Here quit using the RPi for HS3 after Zee 2 came out and tested and used:
        Mini Cube PC (dual core) called the Xi3 Xi5A - BUT it is too big to fit in the media panels.
        Click image for larger version  Name:	xi3.jpg Views:	1 Size:	47.0 KB ID:	1299349
        And currently using the Pine64 2 Gb computer which also is too large for my media panel.
        Click image for larger version  Name:	pine64.jpg Views:	1 Size:	55.6 KB ID:	1299350
        Yes.
        As mentioned above and already running this on the Pine64 2 Gb computer.
        1 - Homeseer 3 Zee 2 version
        2 - Home Assistant running in Docker
        3 - Node Red
        4 - MQTT and Mosquitto
        5 - firewall
        Click image for larger version  Name:	tvbox.jpg Views:	1 Size:	26.4 KB ID:	1299351
        xxx
        - Pete
        Auto mator
        HS4 Lite -
