Force HS3 to ReRead Omni Plugin Names?
  • Force HS3 to ReRead Omni Plugin Names?
    I've been changing some device names in my Omni main panel. I disable/enable the Omni plugin and everything reads fine. But, HS3 doesn't seem to accurately pickup the changes. How can I force HS3 to re-read the names from the Omni plugin?
    Just wondering if it would work to go into plugin>omni>omniconfig>units, and then disable and re-enable the individual renamed units?
      Stopping and restarting the plugin will re-read all the panel info, however, if you already have devices built, you will need to disable/re-enable the units as Pete suggested.
      68 Z-Wave Nodes, 174 Events, 326 Devices
        That did the trick - TYVM!
