Button action causes device cycling
    Greetings,
    I’m running a HomeTrollerZeeS2 with HS3 ZEE S2 Edition 3.0.0.531. Controlling Omni UPB units works great but I have an issue running Button macros to control Simply Automated fan and dual load switches. When the button action is run, the fan starts at the selected speed but then cycles on and off. If a different speed (button) is selected, cycling between speeds begins. The rate is approximately 3 seconds. The only way to terminate the behavior is to restart the home troller. I would appreciate any night or feedback. Direct control using UPB links/scenes would be nice as mentioned by others on the forum.
    R-Cube
