Leviton Omni Notifier News - 28th of May, 2019
    Got this in my inbox yesterday from here:
    hxxps://www.stevesfanclub.com/leviton-hai-omni-notifier-is-no-longer-available-but-there-is-a-solution/
    Omni Notifier 20A30-1 is No Longer Available
    By Stephen Hoh
    May 28, 2019
    Last week, WD (Worthington) was expecting a lot of Omni Notifiers. The news came from Leviton CS, that there was no stock left. When the order was placed, the portal showed sufficient inventory, but either the portal was wrong or someone placed a large order before WD.
    This is just part of the continued phasing-out of the Omni systems. As Leviton’s press release stated, they have stopped production. All that willbe made has been made. Shortages will be part of the process.
    A Notifier Substitute
    The good news is that there is already a solution in place to send notifications from the Omni. If you have been paying attention to the technical bulletins, you would be aware of the HomeSeer solution to add voice control to an Omni. Well, that same product will also add notifications.
    Third Party Solutions
    It is great to see how some third party vendors are stepping in to fill the void left when an Omni-related product is no longer available. PCS did so in a big way.
    Now, HomeSeer’s Omni support is helping to resolve the Notifier absence.
    - Pete
    Auto mator
    HS4 Pro - V4.1.11.0 - Ubuntu 20.01/VB W7e 64 bit Intel Kaby Lake CPU - 32Gb - Mono
    6.10.0.104
    HS4 Lite -
