Running multiple Omni panels from single HS3
  • Running multiple Omni panels from single HS3
    Hello.
    I am currently using 3 separate Omni Pro 2 main panels (not extensions).
    Right now it looks like I am only able to connect to a single one from the Omni plugin on HS.
    Is anyone aware of a way to connect to multiple panels within the same HS3 account? I would like to add automation rules that tie all systems together through HS.
    Thank you
    No, the plugin only supports a single panel per HS instance
