OMNI HS3 plug in fails to download and install
  • OMNI HS3 plug in fails to download and install
    I have windows 10, tried removing the legacy homeseer version of the plugin after purchasing this new version...have HS3 Pro
    I update the plugin page under mange plugins, check the omni plugin box then click on download/install and it tries but ends in a failure...
    Try shutting down Homeseer and using file manager delete any reference to the legacy plugin - IE all DLL, INI files and subdirectories created by the legacy plugin.
    Start up Homeseer and install the Omni Plugin.
    - Pete
    Auto mator
    HS4 Pro - V4.0.9.0 - Ubuntu 18.04/W7e 64 bit Intel Kaby Lake CPU - 32Gb - Mono 6.8X
    HS4 Lite -
      just happened to look at the logs and it says that the hs3pro is old. have 3.0.0.96 need 3.0.0,297...not obvious how to do an upgrade without going the trial route and reload completely
        Not sure if there are plugin dependencies on the version of HS3. I am on V.534 Windows HS3 Pro (test) and Linux HS3 Pro (Production).
        That said shut down HS3, back up the HS3 directory first.
        1 - update HS3
        2 - install the new plugin
        If that doesn't work then post here your results.
        Not sure if you configured anything with legacy plugin (variables - scripts).
        - Pete
        Auto mator
        HS4 Lite -
          Jul-15 9:56:21 AM Updater Install/Update of package OMNI failed.
          Jul-15 9:56:21 AM Updater Error Installation of package OMNI failed. Try disabling the plugin first, then re-try the update.
          Jul-15 9:56:21 AM Updater Error This package requires version 3.0.0.297 of HomeSeer, and you have version 3.0.0.96 so the installation will not continue.
          Jul-15 9:56:21 AM Updater Installing package OMNI
          Jul-15 9:56:21 AM Updater Update hspi_omni.exe downloaded successfully
          Jul-15 9:56:20 AM Updater Downloading update: OMNI
          Jul-15 9:56:20 AM Updater Starting download of updates
          Jul-15 9:56:05 AM Info System registered with MyHomeSeer service successfully.
            Omni was disabled fyi
              i think the homeseer log is an hsd file? if so is there an offline reader?
                all good. upgraded to HS3 Pro Edition 3.0.0.534 (Windows), which allowed the OMNI plug in to load..fixed the config and now see the buttons and outputs I was looking for.
                Minor issues-
                1. CheckDevicesForUpgrade (Thermostat): Object reference not set to an instance of an object.]
                what does this mean--wrong version thermostat for the plugin? thermostat does not register
                2. I don't get an names_codes...panel codes for statusing
                  No. If you see your thermostat with PCA then your should see it in the Omni Plugin. Try disabling plugin, reboot, enabling plugin.
                  I am guessing that you have enabled the devices under the Omni configuration.
                  - Pete
                  Auto mator
                  HS4 Lite -
                    I see the TSTAT with PCA albiet I don't have the first slot filled (removed the first for other reasons) only TSTAT2 is filled with a valid device.
                    disabling, reboot (assuming reboot of HS3) and enabling had no joy.
                    With respect to the panel codes, enabling the device under the omni config drop down in HS3 is correct and what I did for temperature sensors, humidity, buttons etc but nothing comes up for codes and TSTAT's to enable..is there another way via a config file?
                      You enter the thermostat ID in PCA. PCA does not automagically see the thermostat unless you have entered the thermostat ID first.
                      Thinking you need the installer version of PCA to do this.
                      See attached picture.
                      Click image for larger version  Name:	thermostat.jpg Views:	0 Size:	58.7 KB ID:	1315970
                      - Pete
                      Auto mator
                      HS4 Lite -
                        Make sure all your thermostats, units, etc are all 'named' in PC Access. In your thermostat list above, thermostat 1 is named, but thermostat 2 is not.
                        Once named, they will show up in the plugin list.
                        68 Z-Wave Nodes, 174 Events, 326 Devices
                          just named the first and second tstat rows (again ID 1 is unused). disabled and reenabled the plugin no joy...also no codes
                            changed to this restarted an still no thermostat...fyi this is the installers ver of pca
                              Did you 'Write to Controller' after naming?
