Cant complete reading my OMNI controller
    Hi..
    This is my first time writing and actually my real first attempt connecting my OMNI controller to HS2 using the plugin.
    I am unsure if I have a timeout issue, but my HS seems to be freeze reading my OMNI... I cant get out of the reading screen (see picture)
    Could you provide some hints on how to breakthrough?
Name:	OMNI Reading PScreen.PNG
    The plugin only works with US-versions of the panel. Are you using a US panel?
    HS4Pro on a Raspberry Pi4
    HSTouch Clients: 1 Android
      I believe it is using a spanish version... is it the language or also the firmware?
      Not sure how to change that...
      do you have any further suggestion?Click image for larger version
Name:	PC Access view.PNG
        I think that is just the panel language. There should be another place in PC Access to check. When I get home tonight, I'll report back on where to find it.
          thanks... talk to you then
            HI, any luck on finding how to look at the revision?
            I am trying to downlowad an English version firmaware, but not sure if that will make it or not
            regards
              Uploaded IIe english firmware to MS Drive.
              Note: never have switched firmware on the OmniPro 2 and do not know what this update will do to your panel.
              HAI_Omni_IIe_Version_4.0b_(English).cff
              Auto mator
                it is reading now, using the lates US FW, I will now proceed to complete the setup after i made some changes on the initial program
                Thank you
                Regards
                  Sorry guys - tough weekend
                  Let me know if you are still having issues. You might need to enable DEBUG logging in the configuration page.
                    Hi...I am now able to read in Homeseer my OMNI, but can not find the devices on ALEXA.... I am following the next procedure... wondering if there is anything that I am not following correct or if there is any updated document
                    http://communities.leviton.com/docs/DOC-5146/version/2
                      That document is actually the best set of instructions. Is your myhs login info correct?
                        yres it is
                        after log off. disconect the skill on alexa, changing the pwd on myHS account and flag voice on some of my UNITS, i was able to see those trial ones, but have now some difficulty to have ALEXA turn them
                        Seems that there is a connection issue
                        WIll keep trying and let you know if I come with new issues
                        Great support, thank you so much
                        Regards
                          Hi Good day, hope everything is going good and smooth for you.
                          I am running into additional issues.... Hope you can help as you might run into this type of errors before.
                          • I decide to change my ONMI program to better name in English all the units, sensors and temperature sensors
                          • After download into my OMNI Controller i had connect to HS2 and i can see all the new names under Plug-Ins / config OMNI section, but
                          • when I move to HS HOME, is still showing the old program names and units.
                          Could you help me to know how to update the HOME section with the newest program found on Plug-Ins / config OMNI section?
                          Thank you and have a wonderful Friday.
                          I have already try changing my HS password and restarting the Homeseer
                          see the reference files
Name:	new program labels on CONFIG.PNG
ID:	1321287HI there....
Name:	old program labels on HOME.PNG
                            Here's what I found do:
                            Click all the Green checkboxes in the plugin to delete the HS OMNI devices.
                            Then, go into the HS list and remove all the devices using the checkboxes on the left and the pulldown at the top.
                            Now that everything is removed, restart the plugin.
                            Now, go into the OMNI plugin and select just one device and click the checkbox.
                            Make sure it created correctly in HS.
                            Play around with just one device for now, get it working like you want, then add the rest one at a time.
                              great
                              seems that is now recognizing them
                              I will go ahead and turn all the ones I plan to control
                              should I enable voice on all the selected devices?
                              cheers
