I am in the process of integrating HS3 with my Omni Pro II. The main reason for the integration is to allow continued access to modern interfaces like IOS. My Omni Pro II has been rock solid for 15 years and the in wall touch screens are still working great. I have been using HAIKU for mobile access, but that is no longer an option. Anyway, I setup a Raspberry Pi 4B with HS3 standard. I added the Omni plug in and it synced everything and I can see all my devices in HS. However, I moved the devices to different rooms in HS and they all disappeared on my IOS app. I understand this is to do with the root device. Is there a way to set it up with multiple root devices for each room with the Omni devices for that room under the root device for that room? Is there any way to split the Omni devices into multiple rooms or do they all have to be in the same room as the single Omni root device? If they all have to be in the same room, it seems it greatly diminishes the value of the plug in.
TIA for your replies. I am really hoping that my lack of experience with HS is the problem and that there is a workable solution.
Baxter
PS, this is not really an issue for me. I am tech savvy and do not really need a slick interface. However, I am getting ready to put my house on the market and I need the automation to be as user friendly as possible. It will go a long way if the real estate agent can show the purchaser an iPad with all the devices broken down by room. If I just hand them a copy of PC Access and tell them to have fun, it will probably be a different story.
Baxter
