OMNI for HS4
  • OMNI for HS4
    Will you have a new version of OMNI for HS4? I would expect to have to pay something for the HS4 upgrade!
    As of today, HS confirmed that HS3 plugins will work on HS4. The only difference is that the UI might be a little different.
    I do not anticipate charging for an upgrade for HS4. The only thing that would change that, is any significant change to the plugin required by HS4.
    Thanks!
    68 Z-Wave Nodes, 174 Events, 326 Devices
      Thanks for your response.
        Hi Mason,
        By any chance were given a pre-release of HS4 to test with the current Omni plug-in?
        Thanks!
          Yes, and I can already say that things appear to work fine so far in HS4.
          However....
          I will not be making the plugin interface mobile-ready. There's just too much coding overhead to make the plugin look nice on mobile.
          I can imagine wanting to configure your OMNI plugin on mobile. It's just one of those things that you set it up once and never look at it again.
            I'm using the Omni plugin with HS4 and it's working the same as HS3
              However....
              Agreed. Probably would work fine in a regular browser on a pad. I can't envision myself needing to access it from my phone.
              Thank you for all your hard work now and in the past.
                How did you get HS4? Has it been released already? Thanks
                  I meant the beta of HS4
