Log syncing entry
  • Log syncing entry
    What exactly does this log entry mean?
    Legacy-Plugin OMNI Synchronizing OMNI devices with HomeSeer...
    Because I'm assuming it means it's syncing the status of devices but every time I do a restart and I have lights on, the omni P-I does not show them as on.
    Is this Hs4?
    68 Z-Wave Nodes, 174 Events, 326 Devices
      HS3 and HS4
        Does the Omni panel show them as on? The plugin probably only shows the status that the Omni reports, and if lights are changed while the Omni is "off" you would have to have the Omni do a get status. For example, using UPB, if I were to unplug the PIM and then manually turn some lights on, the Omni would not know about it, plugging the PIM back in would not update the status, you would have to tell the omni to do a get a status for each light.
          Yes. It's when I restart HS. Nothing to do with the Omni itself.
          So the lights are on. I restart HS. Omni plugin says syncing. Then shows no lights on. But they are.
            I'll check the code when I get a chance, but it basically traverses the units and gets the current status. I'll report back.
              Yes - that section of code is updating HS from the OMNI status. It sounds like yours is not working? I'll need to investigate further.
                Does yours work?
                Turn on a light.
                Verify it's on in PC Access.
                Restart Homeseer.
                Does the light show as on in Homeseer? in PC Access?
                  Ah - I see that now. I think it is a timing issue. Querying the panel takes quite a while and I think the process to synchronize needs to take place later in the startup process.
                  I'll see what I can do.
                  Thanks for finding this. I dont restart often, so I wasnt aware.
