Event trigger by Omni message content
  • Event trigger by Omni message content
    Rob, can I trigger an event on an Omni message? Example: "Signal: network retry"
    If that message is in the HomeSeer Log, then you can use one of the log monitor plugins to do that.
    If that message is only in the OMNI Log, then you cannot use that as a trigger.
    You might have a network issue with your panel. There are lots of threads on network connectivity issues with the OMNI that can be overcome with installing a small switch/hub or mini router to alleviate the connection issues.
