For quite a while I've been keeping my Omni Panel's clock up to date by sending a command from the HomeSeer Zee to update the panel's clock. I do this with an event scheduled to trigger every 30 minutes. All of a sudden, now the clock on the panel is one hour behind. If I reset the clock at the panel (PCAccess) to the correct time and then run the HS Sync Panel CLock to Controller event, the Omni clock turns BACK by one hour. Some things to note:
- The Omni Panel Setup has DST Enabled (no effect if I disable it)
- The Clock on the Zee controller correctly shows the current internet DST.
- The Zee gets its time info from the internet nist.time.gov to be exact.
- My Location Lat/Long and time zone is set correctly in the panel.
- The log file on the Zee shows the command was issued.
- There are no other time controllers (i.e. eMailBoard) connected to the Omni Panel which could affect the time variance.
