Has the Humidify & Dehumidify Set-points w/RC-2000 TSTATs been corrected in recent releases? Both are showing %'s apx 50% higher that Omni Panel shows. Thanks for your Help...Ken
Humidify & Dehumidify Set-points w/RC-2000 TSTATs showing 50% higher than Panel
Originally posted by klundysr View PostHas the Humidify & Dehumidify Set-points w/RC-2000 TSTATs been corrected in recent releases? Both are showing %'s apx 50% higher that Omni Panel shows. Thanks for your Help...Ken
If you change the setpoint and hit submit, does the panel reflect the right value?HS4Pro on a Raspberry Pi4
54 Z-Wave Nodes / 21 Zigbee Devices / 108 Events / 767 Devices
Plugins: Z-Wave / Zigbee Plus / EasyTrigger / AK Weather / OMNI
HSTouch Clients: 1 Android
Thanks foe the idea, unfortunately I tried submitting new values, they don't update the TSTATs. When you refresh the devices in Homeseer they read apx 50% higher than the values in the Omni-Tstats. All other values/settings work fine, current temps/humidity values AND the Heating and Cooling set points. Just not the Humidify and Dehumidify Set points.
I'm actually in the code now on the thermostat issue. I'll see if I can make progress while I'm in here... stay tuned...HS4Pro on a Raspberry Pi4
