Here's how the settings look:
OMNI Plugin v3.0.2.23
You need to put "Thermostat" in the Voice Command field (right below the Add Category button) - it looks like you left it empty.
HS4Pro on a Raspberry Pi4
HSTouch Clients: 1 Android
- Likes 1
You're right, that field had been left blank. I populated it but again, when I try to do the Reconnect Account for Homeseer in the Google Home app it fails with "Couldn't update the setting. Check your connection", only when this one device is added with the Voice Command Enabled check box. BTW, for the record, the voice command field is blank on my Omni light devices, and they have shown up in the Google Home app as expected with the Homeseer Omni plugin.
That is going to be some connection issue between HS and GH. First, make sure you can connect to myhs.homeseer.com with a browser using your username/password.
Next, go into GH and re-enter your credentials just to make sure they are correct.HS4Pro on a Raspberry Pi4
Originally posted by rmasonjr View PostThat is going to be some connection issue between HS and GH. First, make sure you can connect to myhs.homeseer.com with a browser using your username/password.
I would go here: https://dev.homeseer.com/servicedesk
and open a ticket with HST on this issue. Send them a link to this thread so they can verify your issue.HS4Pro on a Raspberry Pi4
- Likes 1
