I have the HAI plugin (v3.0.1.18) on the Homeseer HS3. I am finding that although this worked fine one week ago, my device status is no longer updating. I have tried rebooting the HS3 and disabling and enabling the plugin to no avail. Can anyone help me to get this working again? I have checked the Omnipro and it seems to be working properly.
Device status not updating
From the OMNI Plugin's Configuration tab, set your logging to DEBUG and let it run for a while. Check it later and see if there are any errors or messages in there.HS4Pro Running on a Raspberry Pi4
68 Z-Wave Nodes, 175 Events, 359 Devices
Yeah, something is not right. If you are using myHS, can you send me your credentials so I can take a look?
email is: robmasonjr67@yahoo.com
Originally posted by gschwob View PostI am having a similar problem with the security devices (contacts and PIR) in the house. They show as secure on SnapLink, but not on My HS or HS Touch.
Under the Configuration tab, set the logging to DEBUG and let it run for a while, then post the logs and I'll see if anything jumps out at me.HS4Pro Running on a Raspberry Pi4
Originally posted by gschwob View Postrmasonjr,
Here you go. I wouldn't have a clue as to what I' was looking at. I understand the concepts, but know enought to stay out of the deep end of the pool.
Disable the MySQL Logging and restart the plugin.
Let it run for a while and see if your devices update.HS4Pro Running on a Raspberry Pi4
RMASORJR...MASTERSEER...KNOWER OF ALL THINGS WONDERFUL. I don't know what's down "at the deep end of the pool," but it must be some pretty good stuff! Thank you, thank you, thank you! I won't ask you how you knew what to do because then you'd probably have to shoot me, but wow! Thanks again.
One final question, should I re-enable SQL Logging?
Originally posted by gschwob View PostRMASORJR...MASTERSEER...KNOWER OF ALL THINGS WONDERFUL. I don't know what's down "at the deep end of the pool," but it must be some pretty good stuff! Thank you, thank you, thank you! I won't ask you how you knew what to do because then you'd probably have to shoot me, but wow! Thanks again.
No, leave SQL Logging off. In a future version, it will be removed.
Thanks!HS4Pro Running on a Raspberry Pi4
