Something strange just started going on with my lights. Jumping ahead to the end of the story, the basic issue is that when I turn my lights up to full brightness using the dimmer switch, they dim back down after a couple of seconds to the last level like something is sending a last level command. The same thing happens when I control the lights using the Homekit app on my phone. Now for the history that might help solve this mystery:
I have Homeseer on a Zee2 running HS3. Works fine so I didn't see a reason to upgrade to HS4 and potentially mess things up.
I have UPB light switches controlled through my Omni. The switches are set up through the Upstart program. Homeseer, of course, talks to the Omni through Rob's plugin. Homekit talks to Homeseer through Homebridge. Everything worked great until recently.
For some reason all the controls in my HS Mobile app disappeared from my widgets. I am not the only one this has happened to apparently. There is another thread about this in the HS Mobile forum. https://forums.homeseer.com/forum/ho...-in-dashboards
Since I couldn't use HS Mobile I downloaded an app called HSBuddy to my iPad. Seemed to work pretty well.
I also recently upgraded the Omni plugin to 3.0.2.23. One thing I noticed when I upgraded was that the "ramp" boxes were checked for all my UPB Homeseer devices whereas I don't think the ramp boxes were checked before. Not 100% sure about that though.
The new app and the upgrade to the Omni plugin are the only changes I have made to my system.
Last night I went to turn on the kitchen lights to full brightness using the wall switch and they went bright and immediately dimmed back down to about 50%. When I held the top rocker they went up and then pulled back down even while I was holding the rocker down with my finger. Then I tried to turn them on full using the Homekit app. Same thing; they went on and immediately dimmed. Finally, I tried the new HSBuddy app and they went on and stayed on. (Its not just the kitchen lights that are doing this. It is all my UPB lights.)
I assumed the HSBuddy app must have stored the last level and when it sensed the light turning on it was sending a last level command and dimming them back down. But that doesn't seem to be what is happening. I sent logs to the developer of the app and he says it is not sending anything in response to a local change from the dimmer switch. You can see the exchange here:
https://forums.homeseer.com/forum/us...-this-is-weird
To make sure I completely powered off the iPad so the HSBuddy app could not operate and the switches still do the same thing, so something else is causing them to dim back down.
That seems to leave the Omni plugin. Any idea what could possibly be going on? I sure could use some help solving this.
