I want to write an automation that will run when the alarm is set to Night Mode, but if I use the trigger, OMNI: User Armed or Disarmed System, System was Set To: Arm Night, By: This User...there is no user to set. When I go to configure the Omni Plugin there is nothing under User Codes. This is in HS4. What am I missing?
No User Codes showing up in Omni Config.
You have a couple of ways to do this:
Go into pcaccess and give your user codes a name. Write the changes to the panel, then restart the plugin. This will import your user codes.
Or, you can use a trigger of a "device changes and becomes..." and use your area mode value of "Arm Night"
Here's an example of the second option:
HS4Pro on a Raspberry Pi4
54 Z-Wave Nodes / 21 Zigbee Devices / 108 Events / 767 Devices
Plugins: Z-Wave / Zigbee Plus / EasyTrigger / AK Weather / OMNI
HSTouch Clients: 1 Android
Originally posted by daruking View PostOne other question. Is there a way to trigger the duress code? I was thinking about using one of my HS-WX300 scene controls to send a duress signal from my OmniPro II.HS4Pro on a Raspberry Pi4
You could do it in a around about way. Wire an output to a zone input, set that zone as a duress. Then when you turn on an OUTPUT (either via homeseer via the plugin trigger off a house light switch, or OMNI programming or whatever) then it would trigger the zone, thus triggering the duress.
Haven't tried it, but there is no reason why it shouldn't work (don't forget the zone resistor)..
