HAI Omni-pro II plugin interface numbers
    I,
    I began programming my HS S-6 pro last week.
    Will replace HAI automation on X-10, Coracess UI, Elan Table top UI, and much more.
    Now, I am trying to understand the alarm-system portion of HAI Omni-pro II plugin interface.
    Need help.
    Thank you
    jyves@videotron.ca<?xml:namespace prefix = "o" ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
    The new Leviton HAI plugin is still in a beta state.
    You can arm / disarm the panel and view configured zones with the plugin via the devices created.
    I have not yet utilized HS3 HSTouch designer at this point in time.
    - Pete
    Auto mator
    HS4 Pro - V4.1.11.0 - Ubuntu 20.01/VB W7e 64 bit Intel Kaby Lake CPU - 32Gb - Mono
    6.10.0.104
    HS4 Lite -
      Hi,
      Yes that works, but since there is no devices for 1-to 10 numbers for keypad, how to make a security on UI ?
      And how can I limit or disable area that are not used ?
      JYA
        For security in HSTouch, you would have to crate your own interface, then have the control run an event to arm/disarm the system. Note that the plugin does not support using the alarm keypad's user codes.
        68 Z-Wave Nodes, 175 Events, 359 Devices
          HAI Omni-pro II plugin interface numbers--Solved
          Hi,
          Found a very simple solution.
          HS3 PassCode on the Disarm screen.
          Very simple, will ask a passcode before acceding the disarm screen.
          JYA
            Yes, but that passcode is not validated against the panel. It is just any number that you hard code into the hstouch project.
            Sent from my SCH-R970X using Tapatalk
              Right, but by putting the HAI panel code, it do the job.
              JYA
