Guys
I'm going to go ahead and release this version since I've had it open so long. There are some new features you guys have been waiting on.
I do still have some outstanding items. Pete, I'm looking into the System Status issue, which contains an issue with AC status and the battery status updates - that is next on my list.
One of the bigger changes was the addition of User Codes. Here's how it works:
A new system device is created for User Codes. It will pull the codes from the panel and allow you to select which codes you want to track/use in HS. By having them in one device, it makes Event creation a little easier. Create an event where the value changes and becomes and you should get triggers when that code is used.
Another large change is to support device creation so that they can be used with HST's implementation of the Amazon Connected Home API. I believe I have the ControlUse properties set correctly, but please check to make sure. I also added more thermostat code to hopefully allow HAI thermostats to get picked up in HSTouch automagically. I'll need some testers on that as well.
Make a backup of your configuration, load it up, and post any issues to this thread please...
Thanks!
Changes in this version:
Attached is the plugin and updater_override.txt files. Here's how to install this beta without using the updater:
**Note - if you are using Linux, make sure you copy the updater_override.txt file and preserve the /r/n line feeds - transfer it in binary and you should be fine.
When the plugin installs and runs for the first time, it will remove the updater_override.txt automatcially.
***Backup your current installation so you can revert back if needed!!
Thanks!
- Fixed - Flag updates are throwing: HandleUnsolicitedPackets Flag Exception: Conversion from string "ON FOR 0:01:00" to type 'Integer' is not valid.
*****User will need to delete/rebuild flags due to class change.***** - Fixed - Change thermostat name so it shows up in HSTouch correctly.
- Fixed - Thermostat hold mode now matches 0/255 off/on.
- Added - Main configuration web page now remembers last active tab.
- Added - DeviceTypeInfo.eDeviceAPI.Thermostat to Capabilities()
- Fixed - Initial Flag Values were not being set on startup.
- Fixed - Issue where Flag values were not being sync'ed on startup.
- Added - RadioRA and RadioRA2 to supported device list.
- Added - updater_override.txt gets removed after beta install.
- Fixed - Setting flags does not execute automation code.
- Added - User codes setup and event support for arm/disarm by user code.
- Added - Filtering of protocol on Units tab.
- Fixed - Issue with ControlUse property being improperly set on devices.
- Added - no longer append Unit number to Unit name.
- Fixed - auto-postbacks now work on Units page without page refresh.
- Fixed - Thermostat operatingstate device did not have correct values.
- Fixed/Added device and thermostat support for Amazon Echo Connected Home API.
- Refactoring older code.
- Copy the attached zip file to your Updates3/Zips folder.
- Copy the attached updater_override.txt file to the HS3 root folder.
- From the Manage Plugins page, disable the HAI plugin if it is running.
- Click on Update Listing.
- You should see the HAI Plugin Beta listed.
- Select and install the plugin.
