Hi Rob,
Just wanted to give you kudos on the plugin. I am in the process of converting over from HS2 (used Tink's HAI plugin). I have to say that your plugin is well planned and solid; every bit as good as the HS2 version. I have a fairly big HAI set up, 64 zones (two hardwire + one enclosure), five thermostats, humidity sensors, lots of outputs. The panel is deeply integrated into my HA system. So far everything works! Are there any user available functions/procedures available or should I just use the devices (it looks like all the function is there)?
Yes, I do plan to buy the plugin, again thanks!
-Ron
-Ron
