What is the relationship between the OPII user codes and Zwave lock (if any)?
I finally got to install a lock (plus enough beaming devices to make it work) and I am at a loss of how do I assigned codes.
HS sees the lock but I can not operate because I believe at least one code has to be assigned.
I am very handywith PC Access and the entire OPII environment but totally new to ZWave.
Does Homeseer take the codes form the OP, the lock itself or do they get programmed into HS (if so , how)?
Thanks in advance.
Thanks in advance.
