Changes in this version:
Attached is the plugin and updater_override.txt files. Here's how to install this beta without using the updater:
**Note - if you are using Linux, make sure you copy the updater_override.txt file and preserve the /r/n line feeds - transfer it in binary and you should be fine.
When the plugin installs and runs for the first time, it will remove the updater_override.txt automatcially.
***Backup your current installation so you can revert back if needed!!
- Fixed thermostat operating state and mode so that thermostats work in HSTouch.
- Refactoring older code.
- Begin work on custom trigger (disabled for this version).
- Copy the attached zip file to your Updates3/Zips folder.
- Copy the attached updater_override.txt file to the HS3 root folder.
- From the Manage Plugins page, disable the HAI plugin if it is running.
- Click on Update Listing.
- You should see the HAI Plugin Beta listed.
- Select and install the plugin.
