The earlier thread "Can't get it to work" looked promising but it looks like bkobistek has a different problem, so I'm starting a new thread.
What I Did:
After the "Initializing..." popup cleared the status changed to "CRITICAL: Plugin has disconnected." (same as bkobistek) and a Windows popup appeared saying that "HSPI_HAI has stopped working" with options to close the program (which I did).
I tried this a couple times and had the same results each time.
My problem differs in that I don't ever seem to make the connection with the panel. It looks like it disconnects as soon as it connects. This would appear to be a credential issue but I double-checked my keys and they are correct.
Any ideas where I should go next?
Jeff
Here is the log file with the first couple of attempts. It tries 5 times and gives up so no need to repeat them:
What I Did:
- I installed the plugin from the Plug-Ins page inside HomeSeer.
- From the Installed Plug-Ins list I clicked the name and was able to enter all the information in the initial Configuration tab. Instructions were to restart the plugin to get it working.
- To re-start I went back to the Plug-Ins/Manage page and disabled the plugin. Once it was disabled I clicked it again to enable the plugin.
Jeff
8/28/2016 1:12:29 PM [2] [Initializing Timers...] 8/28/2016 1:12:29 PM [1] [No panels are configured. Configure your panel, then restart the plugin...] 8/28/2016 1:16:16 PM [2] [PostBackProc: Conversion from string "" to type 'Integer' is not valid.] 8/28/2016 1:16:54 PM [1] [INIFILE set to: HAI.ini] 8/28/2016 1:16:55 PM [2] [Checking for [C:\Program Files (x86)\HomeSeer HS3\updater_override.txt]] 8/28/2016 1:16:55 PM [2] [----C:\Program Files (x86)\HomeSeer HS3\updater_override.txt was not found - ok.] 8/28/2016 1:16:57 PM [2] [HAI Plugin Thread was started.] 8/28/2016 1:16:57 PM [2] [Initializing Timers...] 8/28/2016 1:16:57 PM [2] [Device initialization is complete.] 8/28/2016 1:16:57 PM [2] [HAC Connection state is: Offline] 8/28/2016 1:16:57 PM [2] [Connecting with:[Connecting with: [192.168.1.190] [4369] [TCP]] 8/28/2016 1:16:57 PM [2] [CONNECTION STATUS: Connecting] 8/28/2016 1:16:57 PM [2] [CONNECTION STATUS: Disconnected] 8/28/2016 1:16:57 PM [2] [Lost connection to panel. Attempting retry logic...] 8/28/2016 1:16:57 PM [2] [Attempting reconnect 1 of 5] 8/28/2016 1:16:57 PM [2] [HAI Plugin Thread was started.] 8/28/2016 1:16:57 PM [2] [Initializing Timers...] 8/28/2016 1:16:57 PM [2] [Device initialization is complete.] 8/28/2016 1:16:57 PM [2] [HAC Connection state is: Offline] 8/28/2016 1:16:57 PM [2] [Connecting with: [192.168.1.190] [4369] [TCP]] 8/28/2016 1:16:57 PM [2] [CONNECTION STATUS: Connecting] 8/28/2016 1:16:57 PM [2] [CONNECTION STATUS: Disconnected] 8/28/2016 1:16:57 PM [2] [Lost connection to panel. Attempting retry logic...] 8/28/2016 1:16:57 PM [2] [Attempting reconnect 2 of 5] ... ... 8/28/2016 1:16:59 PM [2] [Connection retry count exhausted. Plugin will gracefully shutdown.]
