Anyone experiencing some recent issues with Simplisafe crashing?
So I have been having some issues with events misfiring (like firing in the middle of the night when nothing has changed) based on simplisafe status changes recently.
Then this evening i noticed there were no more updates to simplisafe statuses in the device list. So i look at the logs and i see this over and over:
the plug in seems to not be starting. so i disabled...and it won't even let me re-enable because it says the plug in is "Loaded Remotely", and this shows up in the log over and over
Tried uninstalling, reinstalling - same thing.
Looked in the event log, and it appears as if the executable is crashing - started on 1/9:
Log Name: Application
Source: .NET Runtime
Date: 1/9/2020 10:57:02 PM
Event ID: 1026
Task Category: None
Level: Error
Keywords: Classic
User: N/A
Computer: HomeSeer
Description:
Application: HSPI_SimpliSafe.exe
Framework Version: v4.0.30319
Description: The process was terminated due to an unhandled exception.
Exception Info: System.FormatException
at Microsoft.VisualBasic.CompilerServices.Conversions.ParseDoub le(System.String, System.Globalization.NumberFormatInfo)
at Microsoft.VisualBasic.CompilerServices.Conversions.ToInteger (System.String)
Exception Info: System.InvalidCastException
at Microsoft.VisualBasic.CompilerServices.Conversions.ToInteger (System.Object)
at HSPI_SimpliSafe.CurrentPlugin.CheckAndCreateDevices()
at HSPI_SimpliSafe.CurrentPlugin.StartupTasks()
at System.Threading.ThreadHelper.ThreadStart_Context(System.Obj ect)
at System.Threading.ExecutionContext.RunInternal(System.Threadi ng.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean)
at System.Threading.ExecutionContext.Run(System.Threading.Execu tionContext, System.Threading.ContextCallback, System.Object, Boolean)
at System.Threading.ExecutionContext.Run(System.Threading.Execu tionContext, System.Threading.ContextCallback, System.Object)
at System.Threading.ThreadHelper.ThreadStart()
Source: Application Error
Event ID: 1000
Task Category: (100)
Level: Error
Keywords: Classic
User: N/A
Computer: HomeSeer
Description:
Faulting application name: HSPI_SimpliSafe.exe, version: 3.0.0.2, time stamp: 0x5d962d85
Faulting module name: KERNELBASE.dll, version: 10.0.18362.535, time stamp: 0x5bd9df62
Exception code: 0xe0434352
Fault offset: 0x001135d2
Faulting process id: 0x1d00
Faulting application start time: 0x01d5c769f777e94d
Faulting application path: C:\Program Files (x86)\HomeSeer HS3\HSPI_SimpliSafe.exe
Faulting module path: C:\Windows\System32\KERNELBASE.dll
Report Id: 16695a13-cc45-4817-a472-bbbc2938e99f
Faulting package full name:
Faulting package-relative application ID:
Source: Windows Error Reporting
Date: 1/9/2020 10:57:03 PM
Event ID: 1001
Task Category: None
Level: Information
Keywords: Classic
User: N/A
Computer: HomeSeer
Description:
Fault bucket 2010314416128480109, type 5
Event Name: CLR20r3
Response: Not available
Cab Id: 0
Problem signature:
P1: HSPI_SimpliSafe.exe
P2: 3.0.0.2
P3: 5d962d85
P4: mscorlib
P5: 4.8.4075.0
P6: 5dd8a2c1
P7: 10a0
P8: 96
P9: System.InvalidCastException
P10:
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER56B4.tmp.md mp
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER57FD.tmp.WE RInternalMetadata.xml
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER581D.tmp.xm l
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER5823.tmp.cs v
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER5853.tmp.tx t
These files may be available here:
\\?\C:\ProgramData\Microsoft\Windows\WER\ReportArchive\AppCr ash_HSPI_SimpliSafe._c3c31b417769055d940af82c11194ebfbfd541b _b712f4e5_c44859b7-75e7-4270-bf68-0fafaa0e39da
Analysis symbol:
Rechecking for solution: 0
Report Status: 268435456
Hashed bucket: d21cb22dab4acde51be6124f742f536d
Cab Guid: 0
........help?!
Jan-09 10:56:11 PM | Starting Plug-In | SimpliSafe loaded in 15008 milliseconds |
Jan-09 10:55:56 PM | Info | Plugin SimpliSafe has connected. IP:127.0.0.1:50454 |
Jan-09 10:55:56 PM | Warning | I/O interface SimpliSafe is down, executable is not running, restarting ... |
Jan-09 10:55:35 PM | Info | Plugin SimpliSafe with instance: has disconnected |
Jan-09 10:55:27 PM | SimpliSafe | 1/9/2020 10:55:27 PMStarting device creation 0 |
Jan-09 10:55:27 PM | User ID | {"userId":XXXXX,"isAdmin":false} |
Jan-09 10:55:25 PM | SimpliSafe | Startup tasks beginning... |
Jan-09 10:55:25 PM | Starting Plug-In | Plugin SimpliSafe started successfully in 136 milliseconds |
Jan-09 10:55:25 PM | Starting Plug-In | Initializing plugin SimpliSafe ... |
Jan-09 11:07:43 PM | Error | Displaying remotely connected interfaces: Object reference not set to an instance of an object. |
Jan-09 11:07:41 PM | Error | Displaying remotely connected interfaces: Object reference not set to an instance of an object. |
Event ID: 1026
Task Category: None
Level: Error
Keywords: Classic
User: N/A
Computer: HomeSeer
Description:
Event ID: 1000
Level: Error
Keywords: Classic
User: N/A
Computer: HomeSeer
Description:
Event ID: 1001
Task Category: None
Level: Information
Keywords: Classic
User: N/A
Computer: HomeSeer
Description:
Event Name: CLR20r3
Cab Id: 0
Problem signature:
P2: 3.0.0.2
P3: 5d962d85
P4: mscorlib
P5: 4.8.4075.0
P6: 5dd8a2c1
P7: 10a0
P8: 96
P10:
Analysis symbol:
Cab Guid: 0
........help?!
