Tigger alarm i.e Emergency
  • Tigger alarm i.e Emergency
    Hi all, is there any way to trigger the emergency/panic routine via an event to instantly set off the alarm? The same way a physical panic button works?
    I wasn't able to find a way to mimic pushing a panic button on my system. I am not sure if the Elk M1 supports triggering a police event via rules.
    Ultrajones
      Thanks for the reply, I've looked through the rules and can't find anyway of doing this
      All I can think of is buying another wireless panic button, and wiring the switch component to a relay triggered by an output.
        If you have a ELK relay attached to the ELK panel, then you could wire the relay contacts to a input on the panel and define it as a panic alarm. I would not use wireless tech on this as it is prone to failure. This way you could keep all of this within the ELK enclosure as well.
          Thanks, that's a great idea! Will look into this!
