Second instance?
  • Second instance?
    Setting up another Elk M1G... wondering if I can use the plugin to run two at once?
    No, sorry. The plug-in only works with one Elk M1 Panel.
    Ultrajones
      Can't one do more than one instance of a plugin with HS3? I thought so.
      Theneach instance would connect to a separate Elk,panel.
        UltraM1G3 HSPI was not designed to run multiple instances.
        Ultrajones
          sad-face. Thanks for confirming.
