Problem with HS3 Devices
    Somehow my HS3 devices became disconnected from my M1 actual status.
    On the plugin page for zones and areas the info/status was correct and updates properly. However, my previously working HS3 devices were no longer updating with changes.
    I noticed in the plugin page, the "HomeSeer Device" was not checked for these zones. I checked them and new devices were created.
    I am now using these new devices for the zones and they are working properly.
    However, I was also having a problem with some of the HS3 Areas devices as well (not updating). AS01. AS02, etc.
    I checked the "HomeSeer Device" to see if that would fix the issue though it did not.
    I then deleted the old HS3 Area devices, hoping that they would be recreated. Though they do not recreate.
    Once I check the box, it stays checked. So I cannot un-check and recheck to trigger the device creation process.
    Is there a way to force the plugin to create the devices?
    Or, how do I clear everything from the plugin (config) and just start over?
    I think the functionality is working now, I just need to get new HS3 devices built.
