Keypad Access as an Event vs Informational
  • Keypad Access as an Event vs Informational
    Hi,
    The following (see attached screen shots) simple event should be triggered with keypad access but it is not.
    The log entries are 'informational' and I'm guessing this is the issue as the events happen when triggered manually.
    Am I missing something to have the keypad access trigger an event?
    Thanks in advance!
    -Philip
    Debug Log has been sent.
    Thanks!
      I tested this and am seeing the same thing. The entry appears in the log:
      Jun-07 16:30:16 Informational Access keypad 02 by Test on 07 June 2017 at 16:30:00
      But it does not trigger an event set up as:
      IF Keypad02 [Garage] accessed by User009 [Test]
      Then
      Set Device Lighting Garage Garage Bench Lights to On
      Marty
      iCore5 Win 10 Pro x64 SSD
      HS3 Pro Edition 3.0.0.435 Windows
      BLOccupied:,Device History:,Yamaha:,UltraMon3:,mcsXap:,Restart:,UltraNetatmo3:, UltraM1G3:,Ultra1Wire3:,BLBackup:,Harmony Hub:,DoorBird:,UltraECM3:,Nanoleaf 3P:,UltraRachio3:,Z-Wave:,SDJ-Health:,BLGarbage:,Blue-Iris:,Chromecast:,Pushover 3P:,EasyTrigger:
        I was able to duplicate the issue. I need to debug to determine why the even isn't firing. I'll let you know when this issue is fixed.
        Ultrajones
          Thank you for reporting this bug. It's fixed in the version I'll be posting later today.
          FYI: I also fixed an issue when using an output change as a trigger.
          Ultrajones
            Thanks for getting this sorted!
              I can confirm that this is working!
                Me too.....thanks Ultra.
