Users Not Selectable
The plug-in only allows you to create devices that have been named using the Elk RP software. It's possible those users numbers were added in later firmware versions. What are users 100 and 101?Plug-ins: UltraMon, UltraM1G, UltraCID, Ultra1Wire, UltraLog, UltraWeatherBug, UltraPioneerAVR, UltraGCIR
Originally posted by Ultrajones View PostThe plug-in only allows you to create devices that have been named using the Elk RP software. It's possible those users numbers were added in later firmware versions. What are users 100 and 101?
Wireless such as a key thob? In the plugin configuration, have you set the user counter value higher or equal to the number of users that have been defined?
I am guessing so, but it is worth a double check. Just saw that the information detail for the users is "unknown". It might be necessary to reload the configuration. See UltraM1G Plugin Options -> Reload Data. Then wait until it reloads all the data from the panel.HomeSeer 2, HomeSeer 3, Allonis myServer, Amazon Alexa Dots, ELK M1G, ISY 994i, HomeKit, BlueIris, and 6 "4k" Cameras using NVR, and integration between all of these systems. Home Automation since 1980.
Originally posted by Krumpy View PostWireless such as a key thob? In the plugin configuration, have you set the user counter value higher or equal to the number of users that have been defined?
