I can't seem to get my Elk M1G communicating with my HomeTroller Zee S2.
I have gone in to ElkRP and made sure that the Serial Port Transmit Options are all selected. I also updated my Elk firmware to make sure that wasn't the problem (it is at 5.3.10 now).
The Zee S2 doesn't have a serial port so obviously I am using a USB to RS232 adapter cable. I have attempted to use 4 different types of these cables but it doesn't seem to make a difference. After I plug them in, they always show up as /dev/ttyUSB0 in the UltraM1G3 options page.
When I go into the device list, the UltraM1G3 Plugin status is Disconnected. When I select Reconnect from the drop-down box, my Log says this:
The Status page for the plugin says this:
I have tried rebooting the Zee S2 as well as rebooting the M1G but those don't help.
Here is my system profile in case you need it:
Like a lot of people, this plugin is one of the reasons I got this system! What can I do to get this working?
Jan-01 2:18:09 PM Informational Could not communicate with Elk M1 ...
Jan-01 2:18:06 PM Informational Updating ELK M1 internal real-time clock to 1/1/2018 2:18:06 PM
Jan-01 2:18:03 PM 1 Error System.InvalidOperationException: Queue empty. at System.Collections.Queue.Dequeue () <0x7491fb7c + 0x00118> in :0 at HSPI_ULTRAM1G3.hspi_plugin.ProcessCommandQueue () <0x72d08138 + 0x00b47> in :0
Jan-01 2:18:03 PM Informational Updating ELK M1 internal real-time clock to 1/1/2018 2:18:03 PM
Jan-01 2:18:00 PM Informational Updating ELK M1 internal real-time clock to 1/1/2018 2:18:00 PM
Jan-01 2:18:00 PM Informational Attemping initial communication with Elk M1 ...
Jan-01 2:18:00 PM Informational Running version has changed, forcing full data download from Elk M1 System ...
Plug-In Status
Status: OK
Version: 3.0.6551.16372
Elk M1 Panel Status
Connection Status: Connected
M1 Firmware: Unknown
M1XEP Firmware: Unknown
Commands In Queue: 0
Last Receive Event: 1/1/0001 12:00:00 AM
Status: OK
Elk M1 Panel Status
Current Date/Time: 1/1/2018 2:41:15 PM
HomeSeer Version: HS3 ZEE S2 Edition 3.0.0.368
Linux version: Linux HomeTrollerZeeS2V2 4.1.19-v7+ #858 SMP Tue Mar 15 15:56:00 GMT 2016 armv7l GNU/Linux System Uptime: 1 Day 0 Hours 23 Minutes 48 Seconds
IP Address: 192.168.1.134
Number of Devices: 23
Number of Events: 6
Available Threads: 390
Enabled Plug-Ins
0.0.0.40: Current Cost 3P
3.0.6551.16372: UltraM1G3
3.0.1.130: Z-Wave
Number of Events: 6
Enabled Plug-Ins
3.0.1.130: Z-Wave
