Seeing Errors In
  • Seeing Errors In
    I am running the latest firmware on the Elk M1G but I am seeing the following warnings and errors in the logs. What is wrong?
    M1 Firmware: 5.3.10
    M1XEP Firmware: 2.0.42
    Jan-29 12:03:37 PM Warning No response/improper response from Elk M1 to command 'cp00'
    Jan-29 12:04:30 PM Warning No response/improper response from Elk M1 to command 'lw00'
    Jan-29 11:07:56 AM Warning No response/improper response from Elk M1 to command 'az00'
    Jan-29 12:03:33 PM Warning No response/improper response from Elk M1 to command 'zs00'
    Jan-29 12:03:28 PM Warning No response/improper response from Elk M1 to command 'cs00'
    Jan-29 11:49:37 AM Warning No response/improper response from Elk M1 to command 'ld01700'
    Jan-29 11:47:41 AM Warning No response/improper response from Elk M1 to command 'sd0400900'
    Jan-29 11:47:38 AM 1 Error System.FormatException: Additional non-parsable characters are at the end of the string. at System.ParseNumbers.StringToInt(String s, Int32 radix, Int32 flags, Int32* currPos) at System.Convert.ToInt32(String value, Int32 fromBase) at HSPI_ULTRAM1G3.hspi_plugin.ProcessReceived(String strDataRec)
    Jan-29 11:47:36 AM Warning Invalid RegExp for data 6341291810A
    Jan-29 11:47:06 AM Warning No response/improper response from Elk M1 to command 'ka00'
    Jan-29 11:47:04 AM 1 Error System.FormatException: Additional non-parsable characters are at the end of the string. at System.ParseNumbers.StringToInt(String s, Int32 radix, Int32 flags, Int32* currPos) at System.Convert.ToInt32(String value, Int32 fromBase) at HSPI_ULTRAM1G3.hspi_plugin.ProcessReceived(String strDataRec)
    Jan-29 11:47:00 AM Warning Invalid RegExp for data 6R54612010064
    Jan-29 11:44:18 AM 1 Error System.InvalidOperationException: Queue empty. at System.Collections.Queue.Dequeue() at HSPI_ULTRAM1G3.hspi_plugin.ProcessCommandQueue()
    Jan-29 11:44:17 AM 1 Error System.InvalidOperationException
    Jan-29 11:44:14 AM Warning No response/improper response from Elk M1 to command 'ld00200'
    Jan-29 11:44:12 AM Warning No response/improper response from Elk M1 to command 'ld00300'
    Jan-29 11:44:09 AM Warning No response/improper response from Elk M1 to command 'ld00400'
    Jan-29 11:44:07 AM Warning No response/improper response from Elk M1 to command 'ld00500'
    Jan-29 11:44:05 AM Warning No response/improper response from Elk M1 to command 'ld00600'
    Jan-29 11:44:03 AM Warning No response/improper response from Elk M1 to command 'ld00700'
    Jan-29 11:44:01 AM Warning No response/improper response from Elk M1 to command 'ld00800'
    Jan-29 11:43:58 AM Warning No response/improper response from Elk M1 to command 'ld00900'
    Jan-29 11:43:56 AM Warning No response/improper response from Elk M1 to command 'ld01000'
    Jan-29 11:43:54 AM Warning No response/improper response from Elk M1 to command 'ld01100'
    Jan-29 11:43:52 AM Warning No response/improper response from Elk M1 to command 'ld01200'
    Jan-29 11:43:49 AM Warning No response/improper response from Elk M1 to command 'ld01300'
    Jan-29 11:43:47 AM Warning No response/improper response from Elk M1 to command 'ld01400'
    Jan-29 11:43:45 AM Warning No response/improper response from Elk M1 to command 'ld01500'
    Jan-29 11:43:43 AM Warning No response/improper response from Elk M1 to command 'ld01600'
    Jean-Marie G. Vaneskahian
    jean@vaneskahian.com
    M1 Firmware: 5.3.10
    Without being able to review the debug output, I can only speculate. Errors and warnings like this are caused by a disruption in communication between the Elk and the UltraM1G3 plug-in. Here are just a few examples of what could have caused this:
    1) The Elk M1 may have reset
    2) The M1XEP may have reset
    3) The network switch between the devices may have reset
    4) The network interface on your HomeSeer system may have reset
    5) The cables connecting the equipment may not be fully seated in the network jack
    6) Your network may have been temporarily saturated
    7) The Elk M1 have been busy and didn't respond before timing out
    8) Your HomeSeer system may have experienced a temporary high load which may have caused the network responses from your Elk M1 to buffer causing it to exceeded the timeout specified in the UltraM1G3 options page
    How often is the issue you reported occurring?
    Ultrajones
      I had turned off the debug mode and cleared the logs because it was getting excessive with those messages. What I can tell you is that all seems to work fine, I have not seen any problems at all that I can tell. But the messages did concern me.
      During the times I saw the messages everything continued to work just fine. The M1 did not reset nor did the M1XEP. There was network connectivity between the HomeSeer and the M1XEP with very little traffic according the the SNMP logs on that managed switch and VLAN. No corrupt or dropped packets. Though I cannot speak to the load on the M1, the load on the dedicated HomeSeer i7 PC was almost zero and HS processed other events ok.
      I will put the M1 plug-in back into debug mode and check the logs. What else should I be doing?
        The "SD", "LD", and others in the output you provided should only be queried during the plug-in initialization. Are you seeing more than a handful of these warnings during normal operation?
          I have it turned on and will keep you posted. My initial thoughts are NO, it may be only during initialization, but I will let you know. I have not been running the plugin long, and that is what I was seeing at first. Perhaps under normal use the messages are not there.
          Thanks for the reply and I will send you an update after 24 hours of me keeping an eye on it and debug being turned on.
            Well here is an output of warnings with nothing really happening (not start up, no arming, no alarms, etc) and all working seemingly ok (The time stamps are there):
            Feb-03 4:39:37 PM Warning No response/improper response from Elk M1 to command 'cx010000700'
            Feb-03 4:38:37 PM Warning No response/improper response from Elk M1 to command 'cx010000700'
            Feb-03 4:37:37 PM Warning No response/improper response from Elk M1 to command 'cx010000700'
            Feb-03 4:36:37 PM Warning No response/improper response from Elk M1 to command 'cx010000700'
            Feb-03 4:35:37 PM Warning No response/improper response from Elk M1 to command 'cx010000700'
            Feb-03 4:34:37 PM Warning No response/improper response from Elk M1 to command 'cx010000700'
            Feb-03 4:33:37 PM Warning No response/improper response from Elk M1 to command 'cx010000700'
            Feb-03 4:32:37 PM Warning No response/improper response from Elk M1 to command 'cx010000700'
            Feb-03 4:31:37 PM Warning No response/improper response from Elk M1 to command 'cx010000700'
            Feb-03 4:30:37 PM Warning No response/improper response from Elk M1 to command 'cx010000700'
            Feb-03 4:29:37 PM Warning No response/improper response from Elk M1 to command 'cx010000700'
            Feb-03 4:28:37 PM Warning No response/improper response from Elk M1 to command 'cx010000700'
            Feb-03 4:27:37 PM Warning No response/improper response from Elk M1 to command 'cx010000700'
            Feb-03 4:26:37 PM Warning No response/improper response from Elk M1 to command 'cx010000700'
            Feb-03 4:25:37 PM Warning No response/improper response from Elk M1 to command 'cx010000700'
            Feb-03 4:24:37 PM Warning No response/improper response from Elk M1 to command 'cx010000700'
            Feb-03 4:23:37 PM Warning No response/improper response from Elk M1 to command 'cx010000700'
            Feb-03 4:22:37 PM Warning No response/improper response from Elk M1 to command 'cx010000700'
            Feb-03 4:21:37 PM Warning No response/improper response from Elk M1 to command 'cx010000700'
            Feb-03 4:20:37 PM Warning No response/improper response from Elk M1 to command 'cx010000700'
            Feb-03 4:19:37 PM Warning No response/improper response from Elk M1 to command 'cx010000700'
            Feb-03 4:18:37 PM Warning No response/improper response from Elk M1 to command 'cx010000700'
            Feb-03 4:17:37 PM Warning No response/improper response from Elk M1 to command 'cx010000700'
            Feb-03 4:16:37 PM Warning No response/improper response from Elk M1 to command 'cx010000700'
            Feb-03 4:15:37 PM Warning No response/improper response from Elk M1 to command 'cx010000700'
            Feb-03 4:14:37 PM Warning No response/improper response from Elk M1 to command 'cx010000700'
            Feb-03 4:13:37 PM Warning No response/improper response from Elk M1 to command 'cx010000700'
            Feb-03 4:12:37 PM Warning No response/improper response from Elk M1 to command 'cx010000700'
            Feb-03 4:11:37 PM Warning No response/improper response from Elk M1 to command 'cx010000700'
            Feb-03 4:04:37 PM Warning No response/improper response from Elk M1 to command 'cx010000700'
            Feb-03 4:02:37 PM Warning No response/improper response from Elk M1 to command 'cx010000700'
            Feb-03 3:40:56 PM Warning No response/improper response from Elk M1 to command 'az00'
            Feb-03 3:40:54 PM Warning No response/improper response from Elk M1 to command 'az00'
            Feb-03 3:40:53 PM Warning No response/improper response from Elk M1 to command 'az00'
            Feb-03 3:36:06 PM Warning No response/improper response from Elk M1 to command 'az00'
            Feb-03 3:36:04 PM Warning No response/improper response from Elk M1 to command 'az00'
            Feb-03 3:36:03 PM Warning No response/improper response from Elk M1 to command 'az00'
            Feb-03 3:35:55 PM Warning No response/improper response from Elk M1 to command 'az00'
            Feb-03 3:35:54 PM Warning No response/improper response from Elk M1 to command 'az00'
            Feb-03 3:35:53 PM Warning No response/improper response from Elk M1 to command 'az00'
            Feb-03 3:32:10 PM Warning No response/improper response from Elk M1 to command 'az00'
            Feb-03 3:32:08 PM Warning No response/improper response from Elk M1 to command 'az00'
            Feb-03 3:30:59 PM Warning No response/improper response from Elk M1 to command 'az00'
            Feb-03 3:30:58 PM Warning No response/improper response from Elk M1 to command 'az00'
            Feb-03 3:30:57 PM Warning No response/improper response from Elk M1 to command 'az00'
            Feb-03 3:28:20 PM Warning No response/improper response from Elk M1 to command 'az00'
            Feb-03 3:28:09 PM Warning No response/improper response from Elk M1 to command 'az00'
            Feb-03 3:28:08 PM Warning No response/improper response from Elk M1 to command 'az00'
            Feb-03 3:28:06 PM Warning No response/improper response from Elk M1 to command 'az00'
            Feb-03 3:27:59 PM Warning No response/improper response from Elk M1 to command 'az00'
            Feb-03 3:27:58 PM Warning No response/improper response from Elk M1 to command 'az00'
            Feb-03 3:27:56 PM Warning No response/improper response from Elk M1 to command 'az00'
            Feb-03 3:27:48 PM Warning No response/improper response from Elk M1 to command 'az00'
            Feb-03 3:27:46 PM Warning No response/improper response from Elk M1 to command 'cv0100'
            Feb-03 3:27:45 PM Warning No response/improper response from Elk M1 to command 'az00'
            Feb-03 3:27:43 PM Warning No response/improper response from Elk M1 to command 'az00'
            Feb-03 3:27:42 PM Warning No response/improper response from Elk M1 to command 'az00'
            Feb-03 3:27:40 PM Warning No response/improper response from Elk M1 to command 'cx010000700'
            Feb-03 3:27:39 PM Warning No response/improper response from Elk M1 to command 'cx010000700'
            Feb-03 3:27:37 PM Warning No response/improper response from Elk M1 to command 'cx010000700'
            Feb-03 3:27:33 PM Warning No response/improper response from Elk M1 to command 'az00'
            Feb-03 3:27:31 PM Warning No response/improper response from Elk M1 to command 'az00'
            Feb-03 3:27:24 PM Warning No response/improper response from Elk M1 to command 'az00'
            Feb-03 3:27:23 PM Warning No response/improper response from Elk M1 to command 'az00'
            Feb-03 3:27:22 PM Warning No response/improper response from Elk M1 to command 'az00'
            Feb-03 3:25:59 PM Warning No response/improper response from Elk M1 to command 'az00'
            Feb-03 3:25:58 PM Warning No response/improper response from Elk M1 to command 'az00'
            Feb-03 3:25:44 PM Warning No response/improper response from Elk M1 to command 'az00'
            Feb-03 3:25:43 PM Warning No response/improper response from Elk M1 to command 'az00'
            Feb-03 3:25:41 PM Warning No response/improper response from Elk M1 to command 'az00'
            Feb-03 3:25:40 PM Warning No response/improper response from Elk M1 to command 'cx010000700'
            Feb-03 3:25:39 PM Warning No response/improper response from Elk M1 to command 'cx010000700'
            Feb-03 3:25:38 PM Warning No response/improper response from Elk M1 to command 'cx010000700'
            Feb-03 3:25:26 PM Warning No response/improper response from Elk M1 to command 'az00'
            Feb-03 3:25:24 PM Warning No response/improper response from Elk M1 to command 'az00'
            Feb-03 3:25:23 PM Warning No response/improper response from Elk M1 to command 'az00'
            Feb-03 3:22:45 PM Warning No response/improper response from Elk M1 to command 'az00'
            Feb-03 3:22:43 PM Warning No response/improper response from Elk M1 to command 'az00'
            Feb-03 3:22:42 PM Warning No response/improper response from Elk M1 to command 'az00'
            Feb-03 3:22:40 PM Warning No response/improper response from Elk M1 to command 'cx010000700'
            Feb-03 3:22:39 PM Warning No response/improper response from Elk M1 to command 'cx010000700'
            Feb-03 3:22:37 PM Warning No response/improper response from Elk M1 to command 'cx010000700'
            Feb-03 3:18:49 PM Warning No response/improper response from Elk M1 to command 'az00'
            Feb-03 3:18:48 PM Warning No response/improper response from Elk M1 to command 'az00'
            Feb-03 3:18:46 PM Warning No response/improper response from Elk M1 to command 'az00'
            Feb-03 3:18:45 PM Warning No response/improper response from Elk M1 to command 'cv0100'
            Feb-03 3:18:43 PM Warning No response/improper response from Elk M1 to command 'cv0100'
            Feb-03 3:18:42 PM Warning No response/improper response from Elk M1 to command 'cv0100'
            Feb-03 3:18:40 PM Warning No response/improper response from Elk M1 to command 'cx010000700'
            Feb-03 3:18:39 PM Warning No response/improper response from Elk M1 to command 'cx010000700'
            Feb-03 3:18:37 PM Warning No response/improper response from Elk M1 to command 'cx010000700'
            Feb-03 3:18:33 PM Warning No response/improper response from Elk M1 to command 'az00'
            Feb-03 3:18:32 PM Warning No response/improper response from Elk M1 to command 'az00'
            Feb-03 3:18:30 PM Warning No response/improper response from Elk M1 to command 'az00'
            Feb-03 3:14:47 PM Warning No response/improper response from Elk M1 to command 'cv0100'
            Feb-03 3:14:46 PM Warning No response/improper response from Elk M1 to command 'cv0100'
            Feb-03 3:14:44 PM Warning No response/improper response from Elk M1 to command 'cv0100'
            Feb-03 3:14:43 PM Warning No response/improper response from Elk M1 to command 'cx010000700'
            Feb-03 3:14:41 PM Warning No response/improper response from Elk M1 to command 'cx010000700'
            Feb-03 3:14:40 PM Warning No response/improper response from Elk M1 to command 'cx010000700'
            Feb-03 3:14:38 PM Warning No response/improper response from Elk M1 to command 'az00'
            Feb-03 3:14:37 PM Warning No response/improper response from Elk M1 to command 'az00'
            Feb-03 3:14:35 PM Warning No response/improper response from Elk M1 to command 'az00'
            Feb-03 3:09:03 PM Warning No response/improper response from Elk M1 to command 'az00'
            Feb-03 3:09:02 PM Warning No response/improper response from Elk M1 to command 'az00'
            Feb-03 3:04:48 PM Warning No response/improper response from Elk M1 to command 'cv0100'
            Feb-03 3:04:47 PM Warning No response/improper response from Elk M1 to command 'cv0100'
            Feb-03 3:04:45 PM Warning No response/improper response from Elk M1 to command 'cv0100'
            Feb-03 3:04:44 PM Warning No response/improper response from Elk M1 to command 'az00'
            Feb-03 3:04:42 PM Warning No response/improper response from Elk M1 to command 'az00'
            Feb-03 3:04:41 PM Warning No response/improper response from Elk M1 to command 'az00'
            Feb-03 3:04:39 PM Warning No response/improper response from Elk M1 to command 'cx010000700'
            Feb-03 3:04:37 PM Warning No response/improper response from Elk M1 to command 'cx010000700'
            Feb-03 3:03:59 PM Warning No response/improper response from Elk M1 to command 'az00'
            Feb-03 3:03:58 PM Warning No response/improper response from Elk M1 to command 'az00'
            Feb-03 3:03:56 PM Warning No response/improper response from Elk M1 to command 'az00'
            Feb-03 3:03:55 PM Warning No response/improper response from Elk M1 to command 'az00'
            Feb-03 3:03:49 PM Warning No response/improper response from Elk M1 to command 'cv0100'
            Feb-03 3:03:48 PM Warning No response/improper response from Elk M1 to command 'cv0100'
            Feb-03 3:03:46 PM Warning No response/improper response from Elk M1 to command 'cv0100'
            Feb-03 3:03:45 PM Warning No response/improper response from Elk M1 to command 'az00'
            Feb-03 3:03:43 PM Warning No response/improper response from Elk M1 to command 'az00'
            Feb-03 3:03:42 PM Warning No response/improper response from Elk M1 to command 'az00'
            Feb-03 3:03:40 PM Warning No response/improper response from Elk M1 to command 'cx010000700'
            Feb-03 3:03:39 PM Warning No response/improper response from Elk M1 to command 'cx010000700'
            Feb-03 3:03:37 PM Warning No response/improper response from Elk M1 to command 'cx010000700'
            Feb-03 3:03:27 PM Warning No response/improper response from Elk M1 to command 'az00'
            Feb-03 3:03:25 PM Warning No response/improper response from Elk M1 to command 'az00'
            Feb-03 3:03:23 PM Warning No response/improper response from Elk M1 to command 'az00'
            Feb-03 2:57:03 PM Warning No response/improper response from Elk M1 to command 'az00'
            Feb-03 2:57:01 PM Warning No response/improper response from Elk M1 to command 'az00'
            Feb-03 2:57:00 PM Warning No response/improper response from Elk M1 to command 'az00'
            Feb-03 2:56:52 PM Warning No response/improper response from Elk M1 to command 'az00'
            Feb-03 2:56:51 PM Warning No response/improper response from Elk M1 to command 'az00'
            Feb-03 2:56:49 PM Warning No response/improper response from Elk M1 to command 'az00'
            Feb-03 2:56:48 PM Warning No response/improper response from Elk M1 to command 'cv0100'
            Feb-03 2:56:46 PM Warning No response/improper response from Elk M1 to command 'cv0100'
            Feb-03 2:56:45 PM Warning No response/improper response from Elk M1 to command 'cv0100'
            Feb-03 2:56:43 PM Warning No response/improper response from Elk M1 to command 'az00'
            Feb-03 2:56:42 PM Warning No response/improper response from Elk M1 to command 'az00'
            Feb-03 2:56:41 PM Warning No response/improper response from Elk M1 to command 'az00'
            Feb-03 2:56:39 PM Warning No response/improper response from Elk M1 to command 'cx010000700'
            Feb-03 2:56:37 PM Warning No response/improper response from Elk M1 to command 'cx010000700'
            Feb-03 2:54:25 PM Warning No response/improper response from Elk M1 to command 'az00'
            Feb-03 2:54:24 PM Warning No response/improper response from Elk M1 to command 'az00'
            Feb-03 2:54:22 PM Warning No response/improper response from Elk M1 to command 'az00'
            Feb-03 2:53:21 PM Warning No response/improper response from Elk M1 to command 'az00'
            Feb-03 2:53:20 PM Warning No response/improper response from Elk M1 to command 'az00'
            Feb-03 2:53:19 PM Warning No response/improper response from Elk M1 to command 'az00'
            Feb-03 2:53:06 PM Warning No response/improper response from Elk M1 to command 'az00'
            Feb-03 2:53:05 PM Warning No response/improper response from Elk M1 to command 'az00'
            Feb-03 2:53:03 PM Warning No response/improper response from Elk M1 to command 'az00'
            Feb-03 2:34:40 PM Warning No response/improper response from Elk M1 to command 'cx010000700'
            Feb-03 2:34:39 PM Warning No response/improper response from Elk M1 to command 'cx010000700'
            Feb-03 2:34:37 PM Warning No response/improper response from Elk M1 to command 'cx010000700'
            Feb-03 2:34:26 PM Warning No response/improper response from Elk M1 to command 'az00'
            Feb-03 2:34:25 PM Warning No response/improper response from Elk M1 to command 'az00'
            Feb-03 2:34:17 PM Warning No response/improper response from Elk M1 to command 'az00'
            Feb-03 2:34:16 PM Warning No response/improper response from Elk M1 to command 'az00'
            Feb-03 2:34:15 PM Warning No response/improper response from Elk M1 to command 'az00'
            Feb-03 12:06:40 PM Warning No response/improper response from Elk M1 to command 'cx010000700'
            Feb-03 12:05:40 PM Warning No response/improper response from Elk M1 to command 'cx010000700'
            Feb-03 12:04:39 PM Warning No response/improper response from Elk M1 to command 'cx010000700'
            Feb-03 12:03:40 PM Warning No response/improper response from Elk M1 to command 'cx010000700'
            Feb-03 12:02:40 PM Warning No response/improper response from Elk M1 to command 'cx010000700'
            Feb-03 12:01:40 PM Warning No response/improper response from Elk M1 to command 'cx010000700'
            Feb-03 11:47:39 AM Warning No response/improper response from Elk M1 to command 'cx010000700'
            Feb-03 11:46:39 AM Warning No response/improper response from Elk M1 to command 'cx010000700'
            Feb-03 11:45:39 AM Warning No response/improper response from Elk M1 to command 'cx010000700'
            Feb-03 11:44:39 AM Warning No response/improper response from Elk M1 to command 'cx010000700'
            Feb-03 10:44:39 AM Warning No response/improper response from Elk M1 to command 'cv0100'
            Feb-03 10:42:39 AM Warning No response/improper response from Elk M1 to command 'cv0100'
            Feb-03 10:41:39 AM Warning No response/improper response from Elk M1 to command 'cv0100'
            Feb-03 10:40:39 AM Warning No response/improper response from Elk M1 to command 'cv0100'
            Feb-03 10:38:39 AM Warning No response/improper response from Elk M1 to command 'cv0100'
            Feb-03 10:29:39 AM Warning No response/improper response from Elk M1 to command 'cv0100'
            Feb-03 10:28:39 AM Warning No response/improper response from Elk M1 to command 'cv0100'
            Feb-03 10:27:39 AM Warning No response/improper response from Elk M1 to command 'cv0100'
            Feb-03 10:26:39 AM Warning No response/improper response from Elk M1 to command 'cv0100'
            Feb-03 10:22:38 AM Warning No response/improper response from Elk M1 to command 'cv0100'
            Feb-03 10:08:38 AM Warning No response/improper response from Elk M1 to command 'cv0100'
            Feb-03 9:31:41 AM Warning No response/improper response from Elk M1 to command 'cx010000700'
            Feb-03 9:31:39 AM Warning No response/improper response from Elk M1 to command 'cv0100'
            Feb-03 9:31:38 AM Warning No response/improper response from Elk M1 to command 'cv0100'
            Feb-03 9:31:36 AM Warning No response/improper response from Elk M1 to command 'cv0100'
            Feb-03 9:31:10 AM Warning No response/improper response from Elk M1 to command 'az00'
            Feb-03 9:31:09 AM Warning No response/improper response from Elk M1 to command 'az00'
            Feb-03 9:31:07 AM Warning No response/improper response from Elk M1 to command 'az00'
            Feb-03 9:31:01 AM Warning No response/improper response from Elk M1 to command 'az00'
            Feb-03 9:30:59 AM Warning No response/improper response from Elk M1 to command 'az00'
            Feb-03 9:30:58 AM Warning No response/improper response from Elk M1 to command 'az00'
            Feb-03 9:30:49 AM Warning No response/improper response from Elk M1 to command 'az00'
            Feb-03 9:30:47 AM Warning No response/improper response from Elk M1 to command 'az00'
            Feb-03 9:30:46 AM Warning No response/improper response from Elk M1 to command 'az00'
            Feb-03 9:30:44 AM Warning No response/improper response from Elk M1 to command 'cx010000700'
            Feb-03 9:30:43 AM Warning No response/improper response from Elk M1 to command 'cx010000700'
            Feb-03 9:30:41 AM Warning No response/improper response from Elk M1 to command 'cx010000700'
            Feb-03 9:30:40 AM Warning No response/improper response from Elk M1 to command 'cv0100'
            Feb-03 9:30:38 AM Warning No response/improper response from Elk M1 to command 'cv0100'
            Feb-03 9:30:37 AM Warning No response/improper response from Elk M1 to command 'cv0100'
            Feb-03 9:30:25 AM Warning No response/improper response from Elk M1 to command 'az00'
            Feb-03 9:30:23 AM Warning No response/improper response from Elk M1 to command 'az00'
            Feb-03 9:30:17 AM Warning No response/improper response from Elk M1 to command 'az00'
            Feb-03 9:30:15 AM Warning No response/improper response from Elk M1 to command 'az00'
            Feb-03 9:30:11 AM Warning No response/improper response from Elk M1 to command 'az00'
            Feb-03 9:30:10 AM Warning No response/improper response from Elk M1 to command 'az00'
            Feb-03 9:30:09 AM Warning No response/improper response from Elk M1 to command 'az00'
            Feb-03 9:29:53 AM Warning No response/improper response from Elk M1 to command 'az00'
            Feb-03 9:29:48 AM Warning No response/improper response from Elk M1 to command 'az00'
            Feb-03 9:29:47 AM Warning No response/improper response from Elk M1 to command 'az00'
            Feb-03 9:29:45 AM Warning No response/improper response from Elk M1 to command 'az00'
            Feb-03 9:29:04 AM Warning No response/improper response from Elk M1 to command 'az00'
            Feb-03 9:28:57 AM Warning No response/improper response from Elk M1 to command 'az00'
            Feb-03 9:28:56 AM Warning No response/improper response from Elk M1 to command 'az00'
            Feb-03 9:28:54 AM Warning No response/improper response from Elk M1 to command 'az00'
              Here is the HSPI_ULTRAM1G3_DEBUG.log
                Screen Capture Of Running Process
                Attached is a screen capture to show you the requested process time... nothing on that system is busy and everything seems to communicate fine except for the errors in the logs.
                  What value do you have set for wait time per command under the Options tab?
                    Here is the wait time
                    Here is a screenshot of the wait time.. I left all this as the defaults...
                      I'll be connecting my Elk M1 test system later today to a new HomeSeer system to see if I can duplicate this.
                      In the meantime, do you happen to have Zoom installed on a system that has access to your HomeSeer system? If yes, I can send you a meeting request and you can share your screen and we can do some debugging.
                      Ultrajones
                        Ultra, through the other thread I have come to believe that it was Microsoft Security Essentials that was causing it. Though it was using NO CPU at all, once I uninstalled MSE, the UltraM1G plugin has generated ZERO warnings for the last 24 hours.
                        I am the 3rd person to confirm this behavior related to the UltraM1G plugin and Microsoft Security Essentials. I will test with another AV program and keep you posted!
                        Thanks for being responsive!
