Cannot ARM System from Plugin
  • Cannot ARM System from Plugin
    When I try to arm the system from the web page
    Elk M1 Area UltraM1G3 Plugin Area
    nothing happens. I can disarm fine the system fine, jyst cant arm it (stay or away). I masked out the pass code and user id in the output log below
    here is the output from the plugin:
    Entered SetIOMulti Subroutine
    SetIOMulti set value: 2, type Values, ref:69
    Entered GetSetting() function.
    Section: Area01, Key: Secret, Value: ****
    Entered AreaAlarmAction() subroutine.
    Sending command: 'a2100****00' to Elk M1, attempt # 1
    Entered SendToM1G() function.
    Sending 0Da2100****0042
    to M1G serial port.
    Waiting for the M1 to respond with 'AS' for up to 1.5 seconds...
    'ntered ProcessReceived() function with a string '17IC00000000000000101007A
    Entered ProcessCommand() subroutine.
    Processing response [IC]
    User001->On KeyPad 01
    Device address User001 was found.
    User **** entered valid user code.
    Entered ProcessReceived() function with a string '1CLD12990011094902150005180039'
    Processing response [LD]
    Processing trigger based on incoming log/event from M1: Event,DURESS
    Entered ProcessReceived() function with a string '1CLD13130011094902150005180046'
    Processing trigger based on incoming log/event from M1: Event,ACCESS KEYPAD 01
    Entered ProcessReceived() function with a string '1EAS00000000111111110000000000'E
    Command AS response received by Elk M1.
    Processing response [AS]
    Area01->0
    Waited 305 milliseconds for the command response.
    Sending command: 'as00' to Elk M1, attempt # 1
    Sending 06as0066
    to M1G serial port.
    Device address Area01 was found.
    Area 01 is Disarmed. Area 02 is Disarmed. Area 03 is Disarmed. Area 04 is Disarmed. Area 05 is Disarmed. Area 06 is Disarmed. Area 07 is Disarmed. Area 08 is Disarmed.
    Area 01 is Ready To Arm. Area 02 is Ready To Arm. Area 03 is Ready To Arm. Area 04 is Ready To Arm. Area 05 is Ready To Arm. Area 06 is Ready To Arm. Area 07 is Ready To Arm. Area 08 is Ready To Arm.
    Area 01 is No Alarm Active. Area 02 is No Alarm Active. Area 03 is No Alarm Active. Area 04 is No Alarm Active. Area 05 is No Alarm Active. Area 06 is No Alarm Active. Area 07 is No Alarm Active. Area 08 is No Alarm Active.
    'ntered ProcessReceived() function with a string '0CAM000000007F
    Processing response [AM]
    Area01->0
    Waited 101 milliseconds for the command response.
    'ntered ProcessReceived() function with a string '16XK5549095150218010005F
    Processing response [XK]
    any help would be appreciated,.
    Current Date/Time: 2/15/2018 10:05:53 AM
    HomeSeer Version: HS3 Standard Edition 3.0.0.368
    System Uptime: 0 Days 0 Hours 1 Minute 55 Seconds
    IP Address: 192.168.1.181
    Number of Devices: 406
    Number of Events: 40
    Available Threads: 600
    Enabled Plug-Ins
    2.0.48.0: BLBackup
    2.0.9.0: BLEmail
    2.0.26.0: BLRing
    3.7.0.0: Harmony Hub
    1.0.0.5: Restart
    3.0.0.21: Sonos
    3.0.6616.28548: UltraM1G3
    3.0.0.76: weatherXML
    3.0.1.184: Z-Wave
    Last edited by mradonis; February 15th, 2018, 10:07 AM. Reason: added support info
    Just wanted to update:
    I am able to arm to stay\away using the
    Armed to next Stay Mode
    Armed to next Away Mode
    but not of the other arm modes work.
