hey! I'm having issues with this plugin disconnecting from my elk m1. I'm running HS on linux and connecting to the elk via the m1xep. I really can't seem to find a pattern as to when it disconnects, seems to be arbitrary and the logs don't help a lot either...
Thoughts?
Apr-01 3:30:41 AM Plug-In Finished initializing plug-in UltraM1G3 Apr-01 3:30:41 AM Informational UltraM1G3 version 3.0.6616.28548 initialization complete. Apr-01 3:30:41 AM Info Plugin UltraM1G3 has connected. IP:127.0.0.1:51952 Apr-01 3:30:40 AM Plug-In Found plug-in: UltraM1G3, version: 3.0.6616.28548 Apr-01 3:30:08 AM Info Plugin UltraM1G3 with instance: has disconnected Apr-01 3:30:08 AM 1 Error System.NullReferenceException: Object reference not set to an instance of an object at HSPI_ULTRAM1G3.hspi_plugin.ShutdownIO () <0x41e67750 + 0x0004f> in :0 Apr-01 3:30:08 AM Shutdown Shutting down plug-in: UltraM1G3 Mar-31 8:44:42 PM Plug-In Finished initializing plug-in UltraM1G3 Mar-31 8:44:42 PM Informational UltraM1G3 version 3.0.6616.28548 initialization complete. Mar-31 8:44:42 PM Info Plugin UltraM1G3 has connected. IP:127.0.0.1:39238 Mar-31 8:44:41 PM Plug-In Found plug-in: UltraM1G3, version: 3.0.6616.28548 Mar-31 8:44:14 PM Info Plugin UltraM1G3 with instance: has disconnected Mar-31 8:44:14 PM Shutdown Shutting down plug-in: UltraM1G3
