Alexa wont update devices
  • Alexa wont update devices
    Having a problem with my ELK M1G . Alexa won't discover any new devices from my HS3. Tried everything. When I updated to .475, my ethernet link went to serial port and when I set it back to ethernet, the ultram1g3 gives me this error.
    WARNING: Failed getting InterfaceStatus from UltraM1G3 - the interface was not found in the list of active interfaces, the list may need to be refreshed.
    It hammers the ethernet connection to my ELK and I cannot restart the interface. I restored to the .291 version of homeseer and I can reconnect via ethernet but as soon as I upgrade to 3.0.0.475 or 3.0.0.484 , and set to ethernet, it wont start the ULTRAM1G3 interface.
    Current Date/Time: 1/12/2019 3:17:53 PM EST
    HomeSeer Version: HS3 ZEE S2 Edition 3.0.0.475 (Linux)
    HomeSeer: Is Registered
    System Uptime: 0 Days 0 Hours 6 Minutes 5 Seconds
    User Name and Access Level: xxxxxx
    LAN IP Address: 192.168.1.110 (HomeTrollerZeeS2V2)
    Client IP Address: 192.168.1.100 (192.168.1.100)
    External IP Address: xx.xx.xx.xx deleted
    Network Adapter: Loopback Address (localhost) IP: 127.0.0.1
    Web Server Address:Port: 192.168.1.110:80
    Number of Devices: 137
    Number of Events: 0
    Event Last Ran: , Ran at 1/1/0001 12:00:00 AM
    Number of unique event scripts used: 0
    Plug-Ins Enabled: Z-Wave:,UltraM1G3:
    Modules/Threads: 57 Modules, 44 Threads
    Available Threads: 390
    HomeSeer Memory Used: 76 Mbytes
    Plug-In Memory Used:
    after hours of wasted time, someone please help me
    Hello Kova3,
    The initial plug-in to Elk synchronization make take several minutes to complete on a slower system like the HomeTrollerZeeS2V2. Have you tried restarting your HomeTrollerZeeS2V2, then waiting about 5 minutes before checking to see if the plug-in is on-line? Subsequent restarts should be significantly shorter in duration.
      sorry I am a noob with regards to the log . The ultrajones interface is having a problem with my ELK ethernet . I have the most recent firmware from Elk. Just found this in the log.
      Ultram1g3 enabled and disabled - initializing plugin - INFO: Plugin start is pending and then get this message
      here is the log when I try to enable ultram1g3 (latest version) 3.0.0.475 and ultram1g3 version 3.0.6922.16073
      Jan-14 8:32:40 PM Informational UltraM1G3 version 3.0.6922.16073 initialization complete.
      Jan-14 8:32:40 PM Warning Attempt by plugin to register a duplicate link of UltraM1G3. Plugin: UltraM1G3 Instance:
      Jan-14 8:32:40 PM Error Data that caused error in ProcessCommand() subroutine: Len=0C, Cmd=ZV, Data=016135, Reserved=00
      Jan-14 8:32:40 PM 1 Error System.ArgumentException: Argument 'Expression' cannot be converted to type 'System.Double'. at Microsoft.VisualBasic.Conversion.Val (System.Object Expression) <0x734bccd8 + 0x00214> in :0 at HSPI_ULTRAM1G3.hspi_plugin.ProcessCommand (System.String strLen, System.String strCmd, System.String strData, System.String strReserved) <0x734a2000 + 0x0a5eb> in :0
      Jan-14 8:32:38 PM Informational Elk M1XEP firmware version 2.0.42 detected.
      Jan-14 8:32:38 PM Informational Elk M1 firmware version 5.2.10 detected.
      Jan-14 8:32:26 PM Error Initializing plug-in(2): UltraM1G3 Instance::Object reference not set to an instance of an objectSTACK: at (wrapper managed-to-native) System.Object:__icall_wrapper_mono_remoting_wrapper (intptr,intptr) at (wrapper remoting-invoke) HomeSeerAPI.IPlugInAPI:InitIO (string) at Scheduler.clsHSPI.CheckInterfaces () <0x7189c7d0 + 0x00283> in :0
      Jan-14 8:31:37 PM Informational Elk Real Time Clock reports: 01/14/2019 20:31:37, mm/dd format, 12 hour format, DST is Inactive
      Jan-14 8:31:36 PM Starting Plug-In Initializing plugin UltraM1G3 ...
      Jan-14 8:31:36 PM Info Plugin UltraM1G3 has connected. IP:127.0.0.1:40274
      Jan-14 8:31:35 PM Plug-In Finished initializing plug-in UltraM1G3
      Jan-14 8:31:06 PM Web Server Web Server authorized local login successful from: 192.168.1.100 User: kova3
        I was having a problem adding new devices, I was running HS beta version .478, Support had me back rev to production version .435. After the downgrade and a reboot, Alexa integration is working fine.
          I cant downgrade to .435 i can only upgrade from .291 to .475 or .495 . .435 is not an option on the setup screen. Is there a place to download it and manually downgrade?
          I did get it to connect by connecting with ElkRP , then firing up the ULTRAm1g3 plugin, wait for a minute, then disconnect from ELK and it reads all the devices. I still get some funky errors but Alexa is back up and working. Obviously a bug someone needs to fix in homeseer or ultram1g3.
            Still waiting from homeseer support for a resolution. I cant disable adn re-enable the ultram1g3 without using ELKrp as a crutch.
              Atr the top of the forum page is a link to downloads, that is where I got .435 from.
