I have configured both the M1G and the plugin. I have verified and see the status of all zones and the system, works great. I can change a zone to bypassed or return it to normal and have verified that it is working in the M1, again works great. As I arm and disarm the system, the plugin captures and updates the devices
What I can't do is send any area 01 command to disarm, arm away, arm stay.... nothing is working
I also can not activate a task, I have one task with a short 5 word message, can not get it to activate, I activate the task, it reports back completed, but no real activation.
I have tried a user pass code that was 4 digits, the same 4 with 00XXXX have change M1 to 6 digit codes and tried that.
I have the password entered and saved in the plugin area tab.
I'm not sure if it is a setting I'm missing or what. The bypass does not require password in M1 config.
I have even tried to create a text rule for the ASCII character string that when it is received on the com port, a rule will arm the system
I would like to be able to arm the system and initiate a task in the M1, It has to be something silly that I have missed. Any ideas...
I followed the instructions, waited a couple of minutes then did the following in order
hit bypass on a zone to unbypass it
hit bypass on the same zone to bypass it
activated task 1
it responded complete but the task did not run
I selected arm away... waited... put it back to disarm to match system.
Update, found that I can select armed to next away mode and it will arm the elf system in away mode, I can then disarm, only control I seem to have.
- What Operating System Are You Using: win 7 on the HS3Pro
- Are you running HomeSeer as a service? (Yes/No) No?
- How is HomeSeer connected to the Elk M1? M1XEP
- Do you run any anti-virus programs? Not on the HS3 Pro
- Describe the issue you are experiencing. Above
- Are you able to duplicate the issue?
- Send the debug log to ultrajones@hotmail.com using the procedure below.
activated task 1
