Using Ultrajones support template:
1. What Operating System Are You Using: Linux (HomeTroller Zee S2)
2. Are you running HomeSeer as a service? Yes
3. How is HomeSeer connected to the Elk M1? serial
4. Do you run any anti-virus programs? no
5. Describe the issue you are experiencing.
If I go to the UltraM1G3 Plug-In configuration page (http://192.168.1.3/UltraM1G3), a completely blank web page shows up.
6. Are you able to duplicate the issue? To duplicate the issue, I disable and re-enable the plugin
7. Unfortunately, since the configuration page is blank, that means I can't enable debug mode through it.
Any recommendations on what else I can try?
I had the plugin working on my Raspberry Pi HomeTroller Zee S2 over serial for a couple of years with only minor issues. Occasionally I needed to reboot to fix the connection but nothing major.
Suddenly something stopped working and I can't seem to re-enable the plug-in.
When I enable the UltraM1G3 plug in, I go check the log and it says:
May-20 11:46:11 AM Error Getting web page from plugin page UltraM1G3:Object reference not set to an instance of an object
May-20 11:45:26 AM Informational UltraM1G3 version 3.0.6922.16073 initialization complete.
May-20 11:45:22 AM Error Initializing plug-in(2): UltraM1G3 Instance::Object reference not set to an instance of an objectSTACK: at (wrapper managed-to-native) System.Object:__icall_wrapper_mono_remoting_wrapper (intptr,intptr) at (wrapper remoting-invoke) HomeSeerAPI.IPlugInAPI:InitIO (string) at Scheduler.clsHSPI.CheckInterfaces () <0x706f1f20 + 0x00283> in :0
May-20 11:44:45 AM Plug-In Finished initializing plug-in UltraM1G3
May-20 11:44:45 AM Starting Plug-In UltraM1G3 loaded in 15042 milliseconds
May-20 11:44:31 AM Starting Plug-In Initializing plugin UltraM1G3 ...
May-20 11:44:31 AM Info Plugin UltraM1G3 has connected. IP:127.0.0.1:58465
