Brand new to the Elk M1 system and the plugin. I'm a Homeseer integrator trying to help my customer integrate his Elk system into our custom app.
I can see the correct Area Arm/Disarmed status in HS4, and also the correct Zone status (Normal, Violated).
I've searched the forum and confirmed the following:
I can bypass the zone from the user's keypad, and the status in the HS4 plugin changes from Violated to Bypassed.
But I cannot send a Bypass command from HS4. I select "Zone Bypass" in the dropdown, and the log shows: No response/improper response from Elk M1 to command 'zb0260002345'
- User code is set in the plugin Areas menu
- ElkRP: Access is NOT checked under User Authorization
- ElkRP: the zone is set to "Bypassable"
