UltraM1G HSPI - Feature Requests
This is a sticky topic.
  • jmaddox
    The M1 control has four selections for Chime: Tone, Voice, Tone/Voice,and Off. I would like to have a way to determine which mode is active.
  • steve6341
    I would like a trigger in Events called "ELK M1 Lighting Trigger" to trigger events when the ELK M1 has received or tranmitted a lighting change. Specifically, I have a WGL W800RF32A X10 RF Receiver connected to a serial port on the M1. I can create an event to trigger when a device's status changes to ON but I cannot re-trigger this event when another ON is received because the status of the device has not actually changed- it is still ON. Basically, I am trying to use the ELK M1 panel and UltraM1G plugin as an interface between the WGL W800RF32A and HomeSeer. Anyone know of a way to do this otherwise?
  • tenholde
    per posting on other thread:
    Could you add the ability to run and Event when any Alarm is sounding?
    tenholde
  • tenholde
    Could you add meaningful device values for the Ethernet Connection device?
    tenholde
  • Ultrajones
    UltraM1G version 1.1.4228.15381 adds support for Analog zone scaling.
    Regards,
    Ultrajones
  • caborabo
    Analog zone scaling - please please please
    Analog values read from the Elk M1 are truncated by the UltraM1G plug-in to the nearest integer.
    The basic version of the request: Apply a global scale factor of 10 or 100 to all analog input values so that the fractional part of voltage is usable/visible. Maybe there is a configurable option to set a scaling factor that defaults to 1.
    The advanced version: Configurable scaling on a per input basis.
  • skybolt
    I would like to see the "Location 2" asignments be dropped on an upgrade/import/install.
    Just leave them where they were. It's time consumeing to switch things back if your not using Location 2.
    Skybolt
  • skybolt
    Well I spoke too soon. I did not catch it right away, but the connection device does not stay in the asigned group, it goes back to UltraM1G after an upgrade.
    Skybolt
  • skybolt
    Originally posted by Ultrajones View Post
    I thought I fixed this. What device types are getting reset?
    I haven't updated in a while, as a result of this, so I guess I will update and see.
    Sorry if I spoke up too late. I will post back.
    Skybolt
    EDIT: MY Bad, You indeed did fix this. My appologies.
  • Ultrajones
    Originally posted by skybolt View Post
    It would be nice to not have a new version change the group name of the plugin devices each time one is installed. i.e. Group name is changed by me to "Elk M1" and I install a new version and the ELK M1 is now back to UltraM1G.
    Skybolt
  • skybolt
    Skybolt
  • scottp73
    Feature REQUEST!!!
    I dont know if this would be part of UltraM1 or another Plug-in!! But What I really want is for homeseer to control My lighting and for the ELK to report lighting from homeseer. Almost like the ISY connected to the ELK!
    Any Time I try to setup lighting with the ELK It reports Wrong due to homeseer changes to my lights settings.
    If there was a way to eather via Lan or By serial connection have the ability to setup what Items in homeseer that I want to control with the ELK. and then Go into the Elk's lighting and set that up and it would report what ever homeseer is reporting. so when homeseer changes light for say at night an turn on out door lighting. The ELK would read that Thoes Lights are on Due to Homeseer says that they are.
    Also when the Elk's keypad is hit to turn on a light, that it sends the command to homeseer to turn on the light. So only one Z-wave(or whatever) controller is needed.
    This would be GREAT for situations where you have a few mixed tech like x10, Zwave, UPB, and such. easy for homeseer to have multi tech and hard for everything ELCE.
    Would love to have this posibility!!
  • skybolt
    Users to the HS Log
    I would like to have the user actions (codes) tracked in the HS log. I did enable the events to the HS log, but that is all of the events and that is way too much. A way of haveing the device actions logged much like a standard HS device would be nice.
  • Kevin L
    I'd like to be able to set a condition "Area XX is NOT disarmed". IOW, a condition that the checks to see if the Elk is armed in any state, Away, Stay, Night, Night Instant, etc.
    Kevin
  • jlegault
    How would I adjust the custom settings without writing a script? It would be nice if you could do this from the status page.
